Maboz 7 Posted January 19, 2019 Posted January 19, 2019 I had added a music library with Emby 3.5.3, a lot of artists were wrongly recognized on musicbrainz, and the bogus data added to kodi by Emby for Kodi, so a bunch of artists are not properly recognized by kodi. Now I updated to Emby 4, did a Emby rescan and now it properly recognized most of the artists in Emby. Though Emby for Kodi doesn't seem to update those artists in Kodi. I tried to Repair the Music Library in Emby for Kodi, but I get this error: 10:33:07.730 T:3052 NOTICE: EMBY.entrypoint.default -> path: params: {}10:33:13.560 T:4552 NOTICE: EMBY.entrypoint.default -> path: ?mode=managelibs params: { "mode": "managelibs" }10:33:17.897 T:4124 NOTICE: EMBY.entrypoint.default -> path: ?mode=updatelibs params: { "mode": "updatelibs" }10:33:24.578 T:8720 NOTICE: EMBY.database -> ERROR:: type: <class 'helper.exceptions.LibraryException'> value:10:33:24.626 T:8720 NOTICE: Previous line repeats 1 times.10:33:24.626 T:8720 NOTICE: EMBY.library -> ERROR:: Traceback (most recent call last): File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\library.py", line 532, in add_library FullSync(self, library_id, update=update) File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\full_sync.py", line 62, in __init__ self.start() File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\full_sync.py", line 158, in start self.process_library(library) File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\full_sync.py", line 215, in process_library media[library['CollectionType']](library) File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\helper\wrapper.py", line 38, in wrapper result = func(self, dialog=dialog, *args, **kwargs) File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\full_sync.py", line 368, in music for items in server.get_artists(library['Id'], False, self.sync['RestorePoint'].get('params')): File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\downloader.py", line 201, in get_artists for items in _get_items(query, server_id): File "D:\Kodi\portable_data\addons\plugin.video.emby\resources\lib\helper\wrapper.py", line 95, in wrapper raise LibraryException("StopCalled") LibraryException10:33:25.231 T:6692 NOTICE: EMBY.entrypoint.default -> path: ?mode=managelibs params: { "mode": "managelibs" } What should I do to make Kodi pick up the updated artists?
sualfred 677 Posted January 19, 2019 Posted January 19, 2019 Have you updated to the Emby for Kodi beta addon? If not, please do it and perform a complete database reset. This is required for Emby 4.
Maboz 7 Posted January 19, 2019 Author Posted January 19, 2019 Have you updated to the Emby for Kodi beta addon? If not, please do it and perform a complete database reset. This is required for Emby 4. Yes, I already did that some time ago, but I did the database reset when the server was 3.5.3 yet, so artist info was wrong at that time. Should I reset the database again (it takes quite some time)
sualfred 677 Posted January 19, 2019 Posted January 19, 2019 Yes, it is required for Emby 4. The server database structure has been changed.
Maboz 7 Posted January 19, 2019 Author Posted January 19, 2019 I restarted Kodi, and now it seems to be syncing music properly. I'll check in a few minutes if it did it.
Maboz 7 Posted January 19, 2019 Author Posted January 19, 2019 It did it, not sure why it didn't work at the previous restart, now it properly synced all artists and Kodi recognizes them... It's a mistery. Thanks for the help, you can close this thread. 1
Solution Angelblue05 4132 Posted January 20, 2019 Solution Posted January 20, 2019 This issue should not happen again with 3.1.45.
