xanthos84 1 Posted January 19, 2019 Posted January 19, 2019 hi, using emby 4.0.2 and using the xtream-editor service to sort my M3U + XML (EPG) from them. But emby is not able to get the XML correct, Error Log: 2019-01-19 09:21:02.886 Info App: xmltv path: https://xtream-editor.com/en/get/epg/ID2019-01-19 09:21:02.886 Info App: Downloading xmltv listings from https://xtream-editor.com/en/get/epg/ID2019-01-19 09:21:02.886 Info HttpClient: GetTempFileResponse url: https://xtream-editor.com/en/get/epg/ID2019-01-19 09:21:04.067 Error App: Error adding metadata *** Error Report *** Version: 4.0.0.2 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: /config Application directory: /system System.Xml.XmlException: System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlReader.ReadToDescendant(String name) at Emby.XmlTv.Classes.XmlTvReader.GetChannels() at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannels(IListingsProvider provider, ListingsProviderInfo info, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.AddMetadata(IListingsProvider provider, ListingsProviderInfo info, List`1 tunerChannels, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(Boolean enableCache, CancellationToken cancellationToken) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlReader.ReadToDescendant(String name) at Emby.XmlTv.Classes.XmlTvReader.GetChannels() at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannels(IListingsProvider provider, ListingsProviderInfo info, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.AddMetadata(IListingsProvider provider, ListingsProviderInfo info, List`1 tunerChannels, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(Boolean enableCache, CancellationToken cancellationToken)
thefarmer 0 Posted January 20, 2019 Posted January 20, 2019 Looks like invalid XML. Hi.. i have the same issue... so when you say 'invalid xml'...what do you mean exactly? Could you advise as to what we should be doing our end to try and resolve? Thnx.
xanthos84 1 Posted January 20, 2019 Author Posted January 20, 2019 its not a invalid xml... its a xml.gz file - and on my side I have build a workaround to extract the gz first so its a final xml, and this xml emby can load without any issues. but as said, i have to do this everytime i load into emby
matty87a 8 Posted January 21, 2019 Posted January 21, 2019 Hi, I just have Emby set to lookup a local xml file for guide data and run this script on a cronjob to keep it up to date: # Automated EPG Grab for Emby from Xtream Editor # Grab Latest XML ### USER AGENT SPOOFING IS TO CIRCUMVENT CURL/WGET BLOCKAGE ### echo Downloading Latest XML File wget --user-agent="Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:21.0) Gecko/20100101 Firefox/21.0" http://xtream-editor.com/en/get/epg/actualurlremoved -O guide.gz gzip -d guide.gz mv guide guide.xml echo Import of EPG Data Complete Hope it helps
raven7558 1 Posted February 22, 2019 Posted February 22, 2019 Hi, I just have Emby set to lookup a local xml file for guide data and run this script on a cronjob to keep it up to date: # Automated EPG Grab for Emby from Xtream Editor # Grab Latest XML ### USER AGENT SPOOFING IS TO CIRCUMVENT CURL/WGET BLOCKAGE ### echo Downloading Latest XML File wget --user-agent="Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:21.0) Gecko/20100101 Firefox/21.0" http://xtream-editor.com/en/get/epg/actualurlremoved -O guide.gz gzip -d guide.gz mv guide guide.xml echo Import of EPG Data Complete Hope it helps This is exactly what I was looking for! Works a charm! Thank you so much for posting this! 1
matty87a 8 Posted March 19, 2019 Posted March 19, 2019 Just in case anyone else stumbles across this - I've since found that Emby can now handle gz guide data well, so you can set the epg as the xtream-editor epg url and set the user agent as below to: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:21.0) Gecko/20100101 Firefox/21.0 This seems to work much quicker than the local xml import
hshah 19 Posted April 2, 2019 Posted April 2, 2019 (edited) Just in case anyone else stumbles across this - I've since found that Emby can now handle gz guide data well, so you can set the epg as the xtream-editor epg url and set the user agent as below to: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.8; rv:21.0) Gecko/20100101 Firefox/21.0 This seems to work much quicker than the local xml import It still doesn't seem to work for me 2019-04-02 11:28:17.506 Info HttpClient: GetTempFileResponse url: https://xtream-editor.com/en/get/epg/XXXXXXXXXXX 2019-04-02 11:28:17.718 Error App: Error adding metadata *** Error Report *** Version: 4.1.0.18 Command line: C:\Users\XXXXXXXXXXX\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 12 Program data path: C:\Users\XXXXXXXXXXX\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\XXXXXXXXXXX\AppData\Roaming\Emby-Server\system System.Xml.XmlException: System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlReader.ReadToDescendant(String name) at Emby.XmlTv.Classes.XmlTvReader.GetChannels() at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannels(IListingsProvider provider, ListingsProviderInfo info, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.AddMetadata(IListingsProvider provider, ListingsProviderInfo info, List`1 tunerChannels, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(Boolean enableCache, CancellationToken cancellationToken) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) /Edit: Can't remember where I actually read about this, but I just removed the S from HTTPS and that seems to have sorted the issue Edited April 2, 2019 by hshah 1
mark-in-dallas 87 Posted May 6, 2019 Posted May 6, 2019 /Edit: Can't remember where I actually read about this, but I just removed the S from HTTPS and that seems to have sorted the issue I could not the get xstream-editor EPG link to work either, but changing the https:// to http:// worked like a charm for me as well. Thank You! I also tried it with and without the the user agent string, and it works either way. 1
Westiewill 16 Posted May 10, 2019 Posted May 10, 2019 anyone get this working w/ emby? I cant get it to work, tried all the suggestions in this thread with no luck. (xtream-editor + emby)
Luke 42245 Posted May 11, 2019 Posted May 11, 2019 anyone get this working w/ emby? I cant get it to work, tried all the suggestions in this thread with no luck. (xtream-editor + emby) Can you please describe the issue that you're having? Thanks.
Westiewill 16 Posted May 11, 2019 Posted May 11, 2019 I was able to fix it, I think I triggered some thing on the api on the IPTV provider and it blocked me for a bit. All good now. Sent from my Pixel 2 using Tapatalk
kikinjo 294 Posted May 11, 2019 Posted May 11, 2019 Xtream edtior does not allow epg downloads from any client, they are checking for useragent. I have cron job to dowload it localy and than use emby to pickup .gz file. I use firefox user agent spoofed in wget command. Also they have daily limit of epg dowloads also, think its 50 times.
