Luke 42237 Posted August 25, 2019 Posted August 25, 2019 How about bring back the top level metadata options (or some out-of-app hack) for us anal retentive types? I can't do that sorry. Having two ways to accomplish the same thing tends to cause mass confusion, and in this case it always did. Emby for WMC might not be up to date with all features given the age of the app. Have you tried turning off legacy browsing? And of course I would make sure that EMC is up to date.
Doctor Bob 9 Posted August 25, 2019 Posted August 25, 2019 I can't do that sorry. Having two ways to accomplish the same thing tends to cause mass confusion, and in this case it always did. Emby for WMC might not be up to date with all features given the age of the app. Have you tried turning off legacy browsing? And of course I would make sure that EMC is up to date. Sounds all too hard. I'll stick with the "01-Movies, 02-TV Shows, etc" naming convention. It works.
ebr 16331 Posted August 25, 2019 Posted August 25, 2019 Hi. Install the Beta version of EMC if you haven't already. In this one app, beta isn't really a testing version but, rather, the version that works best with newer versions of the server.
One2Go 120 Posted August 25, 2019 Author Posted August 25, 2019 This changes the order in the Emby Server but does not change the order in the Emby WMC add-on. I have EHS enable and also have have enabled Legacy Folder Browsing. Not sure if the above settings effect Home Screen --> Library Order positions. However, I do not want to change those settings. As already mentioned you HAVE to install the beta version of EMC there are numerous other things that ONLY will work with the beta version. In addition I am running Throg's themes and in those themes the library order the way it appears in the server is reflected on the home screen.
Doctor Bob 9 Posted June 24, 2020 Posted June 24, 2020 (edited) On 8/25/2019 at 1:51 PM, Luke said: I can't do that sorry. Having two ways to accomplish the same thing tends to cause mass confusion, and in this case it always did. Emby for WMC might not be up to date with all features given the age of the app. Have you tried turning off legacy browsing? And of course I would make sure that EMC is up to date. It's all now very historic but I though I would update this post to say the sorting of library items is now a thing of the past. It was solved in emby server version 4.4. Navigate to: Media --> Home Screen --> Library Order Thank you so much for adding this feature to emby and also the library rename feature. Life just got a lot easier! Edited June 24, 2020 by Doctor Bob
