ntanh1402 0 Posted January 19, 2019 Posted January 19, 2019 Hi all, I'm getting the issue with sync job to google drive. Can you help me overcome it? 2019-01-19 03:53:05.256 Error App: Error transferring sync job file *** Error Report *** Version: 4.1.0.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: /config Application directory: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Couldn't find file 1X0rau5CE2LF6N70bptIDlpko-MDyrarf/S10E199 Holy Birth, The Resurrected Szayel Aporro.avi File name: 'S10E199 Holy Birth, The Resurrected Szayel Aporro.avi' at MediaBrowser.Plugins.GoogleDrive.GoogleDriveService.FindFileId(String name, String parentFolderId, DriveService driveService, CancellationToken cancellationToken) at MediaBrowser.Plugins.GoogleDrive.GoogleDriveService.UploadFile(Stream stream, String[] pathParts, String folderId, GoogleCredentials googleCredentials, IProgress`1 progress, CancellationToken cancellationToken) at MediaBrowser.Plugins.GoogleDrive.GoogleDriveServerSyncProvider.SendFile(SyncJob syncJob, String originalMediaPath, Stream inputStream, Boolean isMedia, String[] outputPathParts, SyncTarget target, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Sync.MediaSync.SendFile(SyncJob job, String originalMediaPath, IServerSyncProvider provider, String inputPath, Boolean isMedia, String[] pathParts, SyncTarget target, SyncOptions options, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Sync.MediaSync.GetItem(IServerSyncProvider provider, SyncTarget target, SyncJobItem jobItem, IProgress`1 progress, CancellationToken cancellationToken) Source: GoogleDrive TargetSite: Void MoveNext() 2019-01-19 03:53:08.274 Error App: Error transferring sync job file *** Error Report *** Version: 4.1.0.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: /config Application directory: /system System.IO.FileNotFoundException: System.IO.FileNotFoundException: Couldn't find file 19fGPVOSQLpVejgUnVp2aQ7gIVGzYBLri/S10E200 The Hardest Body! Cut Down Nnoitra.avi File name: 'S10E200 The Hardest Body! Cut Down Nnoitra.avi' at MediaBrowser.Plugins.GoogleDrive.GoogleDriveService.FindFileId(String name, String parentFolderId, DriveService driveService, CancellationToken cancellationToken) at MediaBrowser.Plugins.GoogleDrive.GoogleDriveService.UploadFile(Stream stream, String[] pathParts, String folderId, GoogleCredentials googleCredentials, IProgress`1 progress, CancellationToken cancellationToken) at MediaBrowser.Plugins.GoogleDrive.GoogleDriveServerSyncProvider.SendFile(SyncJob syncJob, String originalMediaPath, Stream inputStream, Boolean isMedia, String[] outputPathParts, SyncTarget target, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Sync.MediaSync.SendFile(SyncJob job, String originalMediaPath, IServerSyncProvider provider, String inputPath, Boolean isMedia, String[] pathParts, SyncTarget target, SyncOptions options, IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Sync.MediaSync.GetItem(IServerSyncProvider provider, SyncTarget target, SyncJobItem jobItem, IProgress`1 progress, CancellationToken cancellationToken) Source: GoogleDrive TargetSite: Void MoveNext()
Luke 42216 Posted January 19, 2019 Posted January 19, 2019 Hi there, can you please attach the complete emby server log? thanks !
ntanh1402 0 Posted January 19, 2019 Author Posted January 19, 2019 (edited) Hi Luke, thanks for answering me. I tried to remove the whole config folder, run a new server (I'm using docker), scan full library and run sync. It works very smooth about the first 20% of sync process and then the sync process stopped with a lot of errors in log. Here is the whole logs folder. Please help me. https://drive.google.com/open?id=1-cSzArKYGODI2tdq4am4GRLXxPxjN29I Thanks. Edited January 19, 2019 by ntanh1402
Luke 42216 Posted January 19, 2019 Posted January 19, 2019 @@softworkz any thoughts? this usually means the file may have transferred, but then the server can't locate immediately after. thanks.
softworkz 5130 Posted January 21, 2019 Posted January 21, 2019 @@ntanh1402 - You're not running out of storage space on Google drive, I hope? Could you please try to upload one of those files to Google drive manually?
softworkz 5130 Posted January 21, 2019 Posted January 21, 2019 PS: Also, for testing, could you please try to upload a very small video?
ntanh1402 0 Posted January 22, 2019 Author Posted January 22, 2019 @softworkz Thanks for your helping. My google account is an unlimited account so the storage can't run out. I tried to upload a very small video as you said and I couldn't. I think maybe sync process uploaded too much to my account and google stoped allowing to upload to it. I waited for several hours and it can upload again. Thanks for your helping
