FrostByte 5453 Posted January 20, 2019 Posted January 20, 2019 (edited) Ya, it very well could be that combination as you mentioned. There may be some limits there which isn't listed in the user manual Just thought removing that FLAC would eliminate that because that isn't supported in the chart at all Edit: Or convert the FLAC to 2ch PCM which is supported Edited January 20, 2019 by FrostByte
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 (edited) Try removing the FLAC, even if you're not playing that audio track. Don't believe any model supports it and maybe it's seeing and causing issues You're the man! Thank you, sir! That did it. Edited January 20, 2019 by Morbeas 2
FrostByte 5453 Posted January 20, 2019 Posted January 20, 2019 Great. Maybe @@SamES can add something to handle that situation differently like converting FLAC to PCM, or something else, on the fly when it sees it. You probably won't run into this very often though so probably best just to convert/remove it yourself and save the remuxing during playback 1
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 For some reason, Emby won't let me re-scan this file anymore. It refuses to create a new nfo (I've deleted the old nfo) when I do a scan/refresh. I also no longer see a way to delete files from the web interface. Is that no longer an option?
Luke 42241 Posted January 20, 2019 Posted January 20, 2019 For some reason, Emby won't let me re-scan this file anymore. It refuses to create a new nfo (I've deleted the old nfo) when I do a scan/refresh. I also no longer see a way to delete files from the web interface. Is that no longer an option? Why do you feel that Emby won't let you scan the file anymore?
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 I'm not sure. Like I said, even though I deleted the .nfo file, Emby won't create a new one when I do a rescan. I also can't delete the movie from the web interface.
Luke 42241 Posted January 20, 2019 Posted January 20, 2019 Try using the metadata editor and clicking save. Why do you feel you can't delete the movie from the web interface?
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 Because I don't see an option to delete. Has that capability been removed in server 4.x?
Luke 42241 Posted January 20, 2019 Posted January 20, 2019 Have you explored user delete permissions?
FrostByte 5453 Posted January 20, 2019 Posted January 20, 2019 (edited) Do you have a check by the library you want to delete from under Users..Profile in the dashboard? I assume you have the NFO plugin Edit: oops, too late Edited January 20, 2019 by FrostByte
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 My profile has the allow deletion from all libraries box checked.
FrostByte 5453 Posted January 20, 2019 Posted January 20, 2019 (edited) Hmm..working for me. Right under convert I know that doesn't help much Edited January 20, 2019 by FrostByte
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 Anything else I can check? I'm running server 4.0.0.2 on a Synology DS1511+.
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 Ok, if I go to another file, the option to delete is there. So it's just this file (again). I'm going to delete the entire folder, do a rescan, and then add it back to see if that fixes it.
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 Yup, that did it. Thanks again everyone for all your help. Truly appreciated. 1
SamES 1084 Posted January 20, 2019 Posted January 20, 2019 You're the man! Thank you, sir! That did it. So just to confirm, are you saying that the original file will not play, even when you select the DTS track? Or is it only when you select the flac track that it has a problem?
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 One other thing, even though the file has 2 separate audio tracks, Emby does not let me select one. As I stated previously, Emby did not give me the option to select the audio track.
Luke 42241 Posted January 20, 2019 Posted January 20, 2019 Can you show a screenshot of the detail screen that you see on the Samsung TV? Thanks.
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 Don't forget I removed the secondary audio track using MKVToolNix, which is what fixed my issue.
Morbeas 10 Posted January 20, 2019 Author Posted January 20, 2019 While I have your attention, the audio track and subtitle fields are all white like this:
FrostByte 5453 Posted January 21, 2019 Posted January 21, 2019 Odd that it even cared about the FLAC since the DTS-HD track was default 1
