BLWedge09 0 Posted January 18, 2019 Posted January 18, 2019 I'm asking this here, because I'm running emby 4.0.0.2 on Ubuntu 18.04. If you feel it fits better elsewhere, feel free to move it. I have a question about the default and optional recording paths in the server configuration as shown in my attached screenshot. I have the default recording path set to /home/myUser/Storage/embyDVR . embyDVR is both owned by the emby user and in the emby group. no issues there. I'm trying to determine what behavior I would see if I added a movie recording path and series recording path...both inside the embyDVR directory. For example Movie path: /home/myUser/Storage/embyDVR/movies Series Path: /home/myUser/Storage/embyDVR/series Assuming my permissions are ok, will anything continue to be recorded directly to /home/myUser/Storage/embyDVR ? Or, as I would like, could I reconfigure my TV Show library to include just /home/myUser/Storage/embyDVR/series and my movie library to include just /home/myUser/Storage/embyDVR/movies ? Do i risk missing recordings being in a library (I don't have a separate DVR library) if the /home/myUser/Storage/embyDVR directory isn't included in a library ?
Luke 42246 Posted January 19, 2019 Posted January 19, 2019 Hi, welcome. Anything that's not a movie or series would go into the default folder, so for example Sports, or other one-off programs that are not movies. Does that answer your question?
tdiguy 99 Posted January 19, 2019 Posted January 19, 2019 (edited) I am curious on that, would the system show everything from Movie path: /home/myUser/Storage/embyDVR/movies Series Path: /home/myUser/Storage/embyDVR/series Under the system default "recordings" library? I am thinking if they want to segrigate things it might be better to have something like /home/umyUser/Storage/embyDVR/other /home/umyUser/Storage/embyDVR/movies /home/umyUser/Storage/embyDVR/series This way there are 3 different libraries with different paths. With the /home/umyUser/Storage/embyDVR/other set as the default recording path so anything not seen as a series or movie would go there. Edited January 19, 2019 by tdiguy
Luke 42246 Posted January 19, 2019 Posted January 19, 2019 Yes you could do different libraries using the dedicated content types, and then enter the folders from those libraries into dvr settings.
