hein 14 Posted January 24, 2019 Posted January 24, 2019 I don't think that is going to help ottoii as he has manually edited metadata he wants to retain. Or do you have the "Metadata savers: Nfo" and "Save artwork into media folders" options set, ottoii?
ottoii 1 Posted January 24, 2019 Posted January 24, 2019 (edited) - Edited January 27, 2019 by ottoii 1
hein 14 Posted January 24, 2019 Posted January 24, 2019 Library should be holy dont mess with my library plz QFT! Exactly my pov. I don't think you are whining. I am currently in the same boat, see here: https://emby.media/community/index.php?/topic/68369-initial-library-scan-after-3x-4x-prunes-certain-databases/ A possible solution of manually adjusting the DB is being discussed (in German) here: https://emby.media/community/index.php?/topic/68730-metadaten-bearbeitung-in-sqlite-import-von-genres-guid-presentationuniquekey/ A true solution would be for the devs to rethink their stance on the importance of their users' custom metadata and retaining it at all cost. Or at least giving a very visible warning before messing with it.. 1
Luke 42246 Posted January 24, 2019 Posted January 24, 2019 I apologize for the disruption. We will look into whether or not the upgrade can be improved. Thanks. 1
ottoii 1 Posted January 25, 2019 Posted January 25, 2019 (edited) I still dont get any metadata for movies. Its all dir names. Series, i still have info, but it wont show episodes at emby-server at metadata-manager. I still have infos at the emby client app about movies. Will there be a fix? Im the only one with this shitty problem? Why something like this happens? For me, its really not fixed and i cant understand, why something like this has to happen?! Edit: It cant refresh people too. emby has rw access. Cannot access a disposed object. Object name: 'SqliteItemRepository has been disposed and cannot be accessed.'. at Emby.Sqlite.BaseSqliteRepository.CheckDisposed() at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItem(Int64 internalId, CancellationToken cancellationToken) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItem(BaseItem item, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.DeleteItem(BaseItem item, DeleteOptions options, BaseItem parent, Boolean notifyParentItem) at Emby.Server.Implementations.Library.Validators.PeopleValidator.ValidatePeople(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) I think i know now, why this happens. v3 you fucked me with changing emby dir. I had emby-server and for v3, somebody had very good idea to change to emby. So i did ln -s emby-server to emby. Worked, but now its back to emby-server? and now i have that split in config files to emby-server and emby? Edited January 25, 2019 by ottoii
Luke 42246 Posted January 25, 2019 Posted January 25, 2019 Hi there, can you please try refreshing metadata on a movie? Please see if that helps. Thanks !
ottoii 1 Posted January 26, 2019 Posted January 26, 2019 (edited) Thank you. Yes it works on a single movie. I didnt refresh, i replaced metadata. But it dont work on series. I cant see episodes at the metadata-manager, but I still can watch them on emby android app with infos. Edited January 26, 2019 by ottoii
Luke 42246 Posted January 26, 2019 Posted January 26, 2019 Can we please look at a specific example? thanks !
ottoii 1 Posted January 26, 2019 Posted January 26, 2019 (edited) - Edited January 27, 2019 by ottoii
Luke 42246 Posted January 27, 2019 Posted January 27, 2019 @@ottoii, looking at the log, it looked like it picked up the correct MovieDb id: https://www.themoviedb.org/tv/71641-4-blocks?language=en-US If you check the metadata editor in Emby, do the episodes have season and episode numbers assigned?
