pju 10 Posted January 31, 2019 Posted January 31, 2019 Good idea, but no. No difference. I have also tried to stop Windows Firewall - didn't help either.
throgmorton 96 Posted January 31, 2019 Author Posted January 31, 2019 Can you post the log from the newest launch without the square theme loading up Sent from my iPhone using Tapatalk
ebr 16332 Posted January 31, 2019 Posted January 31, 2019 Also, check Windows Event viewer again for anything related to "ehexthost"
pju 10 Posted January 31, 2019 Posted January 31, 2019 Log attached. No events when filtering for ehexthost. But I cannot see it in task manager either before hanging. Have to bail out now, sorry. Talk to you guys later - and thanks a lot for great support ! MBClassic-3112019f09a983270a1431b83712edb980b1f3e.log
pju 10 Posted February 1, 2019 Posted February 1, 2019 Okie, back from family business. Hope it didn't sound like I walking away from my problem - my wife just wasn't quite happy at the time :-) I have made a capture with Microsoft Network Monitor - don't know if a .cap could be of any help. Also have a capture from SysInternals Procmon with lots and lots of lines from ehexthost.exe. But since I don't know what to look for is it a bit hard to understand. Could this help us forward?
ebr 16332 Posted February 1, 2019 Posted February 1, 2019 Do you see anything that looks like an error? Is it possible this is just a display issue? Is it a 4:3 screen by any chance?
pju 10 Posted February 2, 2019 Posted February 2, 2019 (edited) Ha, You are a genius Not a 4.3 but since it is running under VMware Workstation I had picked a resolution (2560x1600) suiting me best in respect to what else is on my monitor. WMC and EMC works fine with this solution - apparently just not the themes stuff. I changed to 1920x1080 and 2560x1440 and both worked out fine! So lesson learned and problem solved - thanks a lot PS: a last question - can I go back to my 307 version from 317 on my production system if I need? Any files to backup before upgrading? Edited February 2, 2019 by pju
ebr 16332 Posted February 2, 2019 Posted February 2, 2019 PS: a last question - can I go back to my 307 version from 317 on my production system if I need? Any files to backup before upgrading? No, there shouldn't be any issue with that. Thanks.
pju 10 Posted February 4, 2019 Posted February 4, 2019 No, there shouldn't be any issue with that. Thanks. Just for feedback. Works perfectly on my 3.5.3.0. The theme download is working - and I even got my folders sorted correctly again Thanks a lot.
