cparadela 0 Posted January 17, 2019 Posted January 17, 2019 Hello everyone, I'm using emby for around a month also with the premiere key as well. I have the QNAP TS-877 and planning to buy a GeForce® GTX 1060 Mini. The question is, will I get some advantage by getting that card when I'm using emby? Will the transcoding or performance when I'm playing a 4K UHD movie will be increased? So far I'm able to watch a movie 4k HDR or UHD without a problem by using pure CPU processing power, but I don't know if adding a GPU will make things better. Hope I can explain myself correctly.
Luke 42241 Posted January 17, 2019 Posted January 17, 2019 Hi, it depends on how you define better. It won't necessarily make it look better. What it might do is allow you to offload that transcoding to the GPU so that the machine can perform other tasks at the same time. Does that help answer your question? 1
Solution Trexx 1 Posted January 17, 2019 Solution Posted January 17, 2019 (edited) It currently won’t work due to Qnaps NVidia drivers being too old. Supposedly Qnap will be updating their Nvidia drivers once they have released QTS 4.4. Edited January 17, 2019 by Trexx 1
cparadela 0 Posted January 17, 2019 Author Posted January 17, 2019 Thanks for answering Luke. For sure I know the load will be processed by the GPU, but according to Trexx's mention, the problem will be the QNAP not using the graphic card resources (that's what I guess). I'm not using emby over a Windows or Linux virtual machine. It's running as an application installed straight on the QNAP (.qpkg).
Luke 42241 Posted January 18, 2019 Posted January 18, 2019 Yes and the outdated driver issue is true as well, so you may want to wait until QTS 4.4 is released before making your decision.
cparadela 0 Posted January 18, 2019 Author Posted January 18, 2019 Yes and the outdated driver issue is true as well, so you may want to wait until QTS 4.4 is released before making your decision. Thanks for your answer. With that said I won't buy something that's not going to be used for what I need. Just curious, how is possible to use the graphic card assuming this issue would never existed before?
Luke 42241 Posted January 18, 2019 Posted January 18, 2019 Emby would detect it and use it automatically, assuming a compatible driver version. 1
seer_tenedos 0 Posted February 16, 2019 Posted February 16, 2019 Any idea when QTS 4.4 is expected to be released? I have a TVS-1282 and Quadro P2000 but just released i can't use the quadro for encoding in emby cause of the stupid nvidia driver being too old.
phillipmcmahon 1 Posted February 16, 2019 Posted February 16, 2019 They have it in testing for a whole bunch of models, I have a TS-673 and desperately hoping 4.4 provides newer drivers that enable both Plex and Emby to take advantage of my 1050 TI...
OneCD 10 Posted March 18, 2019 Posted March 18, 2019 Well, it kinda-sorta has-been for a small number of NAS models since January: /Storage/TS-X53D/TS-X53D_20190119-4.4.0.0820.zip/Storage/TS-X72/TS-X72_20190119-4.4.0.0820.zip/Storage/TS-X72U/TS-X72U_20190119-4.4.0.0820.zip ... but still no-word regarding timelines for all other current models. https://forum.qnap.com/viewtopic.php?f=5&t=146416
PenkethBoy 2068 Posted March 18, 2019 Posted March 18, 2019 as always there are exceptions with QNAP - new hardware thats not compatible with the old kernel etc
OneCD 10 Posted March 18, 2019 Posted March 18, 2019 Agree. I suspect QNAP are using those models as guinea-pigs to test QTS 4.4.
PenkethBoy 2068 Posted March 19, 2019 Posted March 19, 2019 Yes glad i'm not a guinea-pig - based on the number of 4.3.5/6 updates that have caused huge problems for users Although the last couple of updates have addressed bugs quickly (for qnap)
Moogle Stiltzkin 1 Posted May 29, 2019 Posted May 29, 2019 (edited) Emby would detect it and use it automatically, assuming a compatible driver version. testing with the emby and with QTS 4.4.1 https://www.qnap.com/qts/ i don't see the hardware transcoding for nvidia graphics card working (i have use hardware acceleration enabled, then i check the video stats during playback to confirm status). then again i don't have premiere, maybe thats why. i'd love to help test if i could ts-877 + nvidia 1050 gtx graphics card Edited May 29, 2019 by Moogle Stiltzkin
Luke 42241 Posted May 29, 2019 Posted May 29, 2019 Did you try changing the option to advanced to see if anything was detected?
Moogle Stiltzkin 1 Posted June 1, 2019 Posted June 1, 2019 (edited) Did you try changing the option to advanced to see if anything was detected? let me check then get back to you. i thought i did. i see this so i tried to play a video but i'm not sure it's using the gpu :/ Edited June 1, 2019 by Moogle Stiltzkin
Luke 42241 Posted June 1, 2019 Posted June 1, 2019 Well that looks very good ! The fact that they're being detected shows that it should work, given Emby Premiere. This is the first time we've ever seen Nvidia GPU's detected on QNAP. 1
phillipmcmahon 1 Posted June 1, 2019 Posted June 1, 2019 Seems to be doing something with the GPU. I forced a transcode and the GPU usage for the first time went from 0% to non 0%. However I still see high CPU utilisation, even on movies that are direct streaming. I was seeing 33% CPU on one movie playback whereas the same in Plex was under 3%. 1
Luke 42241 Posted June 1, 2019 Posted June 1, 2019 Seems to be doing something with the GPU. I forced a transcode and the GPU usage for the first time went from 0% to non 0%. However I still see high CPU utilisation, even on movies that are direct streaming. I was seeing 33% CPU on one movie playback whereas the same in Plex was under 3%. We'd have to look at an example. Thanks.
