Upgrade or Fresh Install for v4
Suggestions? Anything to be gained by doing a fresh install? Sounds like the data structure has changed, so maybe a fresh install will help with any cruft left over from the various 3.x updates in the past?
If you don't have much customized or edited meta-data then doing a fresh install could very well be your best option.
Personally I'd look at the paths listed on the Dashboard for your current system and then backup or rename them (just in case), then do the fresh install.
Most people will probably want to do an update.
Edited by cayars
