rljnc 2 Posted January 17, 2019 Posted January 17, 2019 Okay excuse me I am not sure what this setting was, but before the upgrade I was able to combine to of my recordings media folders into one one the home screen, so I use hdhomerun and emby for tv recordings and I have two different folders, before the upgrade there was an easy setting I think it was under home screen settings where I could just check it and both of these folders showed as one. This was great to see all my tv recordings in one place and keep up with what I watched, but this does not seem to be there anymore.
Spaceboy 2573 Posted January 17, 2019 Posted January 17, 2019 Okay excuse me I am not sure what this setting was, but before the upgrade I was able to combine to of my recordings media folders into one one the home screen, so I use hdhomerun and emby for tv recordings and I have two different folders, before the upgrade there was an easy setting I think it was under home screen settings where I could just check it and both of these folders showed as one. This was great to see all my tv recordings in one place and keep up with what I watched, but this does not seem to be there anymore.you now have to do this in the library set up
rljnc 2 Posted January 17, 2019 Author Posted January 17, 2019 Are you saying I would need to add a new media library and specified both folders?
ebr 16337 Posted January 17, 2019 Posted January 17, 2019 Hi. Please see: New Folder-based Access Control
rljnc 2 Posted January 17, 2019 Author Posted January 17, 2019 Okay never mind figured it out, did not understand I had to setup the libarary with a mount point folder say okay to that, then go back in to manage library then I could add anouther mount piont folder.
Solution ebr 16337 Posted January 17, 2019 Solution Posted January 17, 2019 Okay never mind figured it out, did not understand I had to setup the libarary with a mount point folder say okay to that, then go back in to manage library then I could add anouther mount piont folder. You can add multiple folders. Just hit the "+" sign, select a folder, then hit the "+" sign again. When done, hit save. 1
rljnc 2 Posted January 17, 2019 Author Posted January 17, 2019 Okay got it, maybe I am going crazy, because I was sure I tried that to start with and it would not let me do that, anyway working now and thanks for the help.
