EduardoSantos 40 Posted January 16, 2019 Posted January 16, 2019 Hi, Just installed the new 4.0.0.2 version. It seems to be everything ok up to now though on detail screens, the header shows sabe genre twice. This occurs to - Music albuns; - Music artists; - Movies If I open the metadata editor and save the same data with no modifications Emby stops showing double genres
Luke 42216 Posted January 16, 2019 Posted January 16, 2019 Going forward it should be pretty difficult for this to happen again, but it may have happened following the upgrade due to issues with the old data.
EduardoSantos 40 Posted January 16, 2019 Author Posted January 16, 2019 Yes, I noticed a database update runs after the upgrade. I will try a rescan to see if this will go away.
EduardoSantos 40 Posted January 24, 2019 Author Posted January 24, 2019 Just to inform all duplicates gone away.
