cramerjd@gmail.com 0 Posted January 29, 2019 Author Posted January 29, 2019 No, just an edgerouter X router
cramerjd@gmail.com 0 Posted February 4, 2019 Author Posted February 4, 2019 I'm the only one with this issue I'm assuming?
Luke 42241 Posted February 5, 2019 Posted February 5, 2019 do you have any other devices available that you could use to test this with and compare?
cramerjd@gmail.com 0 Posted February 7, 2019 Author Posted February 7, 2019 I've tried with my note 9, note 4, S7 edge and a BlackBerry Keyone. Same result. Clearly my encoding type is to blame but only for android and only for the embedded player. VLC is perfect.
Luke 42241 Posted February 7, 2019 Posted February 7, 2019 Can you provide a sample video for testing? thanks.
cramerjd@gmail.com 0 Posted February 8, 2019 Author Posted February 8, 2019 I guess not? When I cut down the video using the option not to mux at all (so it should preserve all the video and audio codecs) the video doesn't stutter at all. In the specs when playing its identical to the full file in every way, but no stutter. I'd have to have you play the entire movie file. I'm trying different MP4/MKV editors to find one that outputs a file that isn't modifying whatever this is modifying. I'll keep my Plex server spun up for local android playback for now. Unfortunately its what I watch movies with the most.
Luke 42241 Posted February 10, 2019 Posted February 10, 2019 When I cut down the video using the option not to mux at all (so it should preserve all the video and audio codecs) the video doesn't stutter at all. That's interesting, so then what are the differences before and after?
cramerjd@gmail.com 0 Posted February 10, 2019 Author Posted February 10, 2019 Not sure. The bitrate seems to go down but that's it.
Luke 42241 Posted January 19 Posted January 19 For video stuttering, please try Emby for Android 3.5.25 and let us know how that compares: https://emby.media/emby-for-android.html Thanks.
