kmed27 19 Posted January 16, 2019 Posted January 16, 2019 I have just noticed since to 1.0.5x update that audio option and subtitle option combo boxes display white on white so you cannot see the what is selected. I normally get rid of subtitles and multiple audio settings; hence not noticing for a while. If you select the combo, it displays the detail for selection ok, it's just the combo box display itself that you cannot read on the TV. I tried changing the theme but that had no effect on it. My TV is Samsung: Model: EU65HU8500 with SEK-3500u (Tizen)Firmware: 1530Emby Client: 1.0.54 1
Luke 42241 Posted January 16, 2019 Posted January 16, 2019 So this is 2014 tizen? @@SamES can you reproduce?
kmed27 19 Posted January 16, 2019 Author Posted January 16, 2019 No, with the sek- 3500 box it makes it a 2015 tizen model. 1
SamES 1084 Posted January 18, 2019 Posted January 18, 2019 So this is 2014 tizen? @@SamES can you reproduce? Not seeing it on 2017 models. I'll need to test this for 2015
kmed27 19 Posted January 18, 2019 Author Posted January 18, 2019 (edited) I have added a screen shot so that you can see what I am getting, in case it helps. Edited January 18, 2019 by kmed27 1
SamES 1084 Posted January 18, 2019 Posted January 18, 2019 Can you please confirm which theme you are using? Thanks
zachary24 3 Posted January 19, 2019 Posted January 19, 2019 Happening to me too (Samsung mu6290 2016) in the standard dark theme, It happened the moment I updated, I only use versions, so it's not too much of a deal to me..
kmed27 19 Posted January 19, 2019 Author Posted January 19, 2019 Can you please confirm which theme you are using? Thanks I have tried various themes to see if it changed it but it didn't the current theme that I left it on is Blue Radiance, I was origionally using Dark with Green.
