CBers 7546 Posted January 16, 2019 Posted January 16, 2019 If you have the "Extract chapter images during the library scan" option enabled in your library settings, then the initial library scan could take longer than normal. You can stop the scan, disable that option on each library and rerun via the Scheduled Task. Once completed, re-enable the option. Any missing Chapter Images can be re-created via the "Chapter image extraction" scheduled task. 1
