EODCrafter 181 Posted January 16, 2019 Posted January 16, 2019 I have searched for this with no luck...How do I disable the clicking noise when going thru the Guide on FireTV App?
EODCrafter 181 Posted January 16, 2019 Author Posted January 16, 2019 Is this it or can I do it in Just Emby? http://www.tomsguide.com/faq/id-3824085/turn-clicking-sounds-navigation-fire.html
ebr 16337 Posted January 16, 2019 Posted January 16, 2019 You would need to turn off navigation sounds on the device.
Solution EODCrafter 181 Posted January 16, 2019 Author Solution Posted January 16, 2019 (edited) You would need to turn off navigation sounds on the device. Found it @@ebr. I only use that with Emby so I never realized it's not Emby related. http://www.tomsguide.com/faq/id-3824085/turn-clicking-sounds-navigation-fire.html Edited January 16, 2019 by EODCrafter
