easperhe 4 Posted January 15, 2019 Posted January 15, 2019 All, While at home, my work laptop runs Emby Theater to connect to Emby Server with no issue. But it won't work at work. I can connect to the server and see the TV shows and music. But, I can't play any of them. After a long spinning circle, I will get "Playback Error. No compatible streams ..." Note, the web client does work. I suspect that the work proxy server is blocking something. Any ideas how to fix and/or get around this?
Luke 42242 Posted January 15, 2019 Posted January 15, 2019 I suspect that the work proxy server is blocking something. Very possibly. Can we look at an example? Please attach the information requested in how to report a media playback issue. Thanks !
easperhe 4 Posted January 15, 2019 Author Posted January 15, 2019 Attached is the Emby Server Log.txt and the error message I get when trying to use Emby Theater at work. Emby Server Log.txt
Luke 42242 Posted January 16, 2019 Posted January 16, 2019 Thanks. Are you able to play using the web app?
