Xpenology Emby Transcoding on J4105 iGPU
Thanks @@frogger, I'll pick this up again tomorrow. The output from 'vainfo' looks good, and confirms we have access to the GPU and it's responding as expected.
Best
-James
...one other thing, can you post a screenshot of the 'Media Info' for this video - you can find this at the bottom of the page for the video in the Web UI.
Best
- James
Hello @@frogger
We're going to need to iterate a little to pinpoint exactly what the issue is here. From the h/w detection logs, there are no material differences, attached for reference.
When running under Ubuntu, did you happen to notice the CPU utilisation whilst transcoding this file?
Can you run the following from an SSH session to your XPEnology system and post the output here:-
sudo /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format vaapi -i file:"/volume1/data/test/BigBuckBunny_2000hevc.mp4" -f null -
This is a simple test to see if we're actually managing to decode the source file.
Best
- James
xpen_hardware_detection.txt
u1804_hardware_detection.txt
Yes, I've been monitoring it using htop and intel_gpu_top. Neither showed any significant change in utilization during playback, which might be caused by the shortness of the video in combination with the update interval of these tools.
Password:
ffmpeg version 4.0.2-emby_2018_12_09-20181220T011603UTC Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7.3.0 (GCC)
  configuration: --prefix=/var/packages/EmbyServer/target/ffmpeg --enable-cross-compile --cross-prefix=x86_64-syno-linux-gnu- --target-os=linux --disable-rpath --enable-pthreads --arch=x86_64 --enable-libzimg --enable-libmfx --enable-vaapi --enable-x86asm --enable-gpl --enable-shared --disable-static --disable-debug --disable-ffplay --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --enable-gnutls --enable-libass --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libfreetype --enable-fontconfig --enable-gray --enable-libfribidi --enable-libvidstab --enable-libzvbi --disable-indev=sndio --disable-outdev=sndio --extra-version=20181220T011603UTC --extra-libs='-luuid -lstdc++'
  libavutil      56. 14.100 / 56. 14.100
  libavcodec     58. 18.100 / 58. 18.100
  libavformat    58. 12.100 / 58. 12.100
  libavdevice    58.  3.100 / 58.  3.100
  libavfilter     7. 16.100 /  7. 16.100
  libswscale      5.  1.100 /  5.  1.100
  libswresample   3.  1.100 /  3.  1.100
  libpostproc    55.  1.100 / 55.  1.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file:/volume1/data/test/BigBuckBunny_2000hevc.mp4':
  Metadata:
    major_brand     : iso4
    minor_version   : 1
    compatible_brands: iso4hvc1
    creation_time   : 2014-08-25T21:13:56.000000Z
  Duration: 00:00:10.00, start: 0.083333, bitrate: 2013 kb/s
    Stream #0:0(und): Video: hevc (Main) (hvc1 / 0x31637668), yuv420p(tv), 3840x2160, 2010 kb/s, 24 fps, 24 tbr, 24k tbn, 24 tbc (default)
    Metadata:
      handler_name    : hevc:fps=24@GPAC0.5.1-DEV-rev4807
Stream mapping:
  Stream #0:0 -> #0:0 (hevc (native) -> wrapped_avframe (native))
Press [q] to stop, [?] for help
Output #0, null, to 'pipe:':
  Metadata:
    major_brand     : iso4
    minor_version   : 1
    encoder         : Lavf58.12.100
    Stream #0:0(und): Video: wrapped_avframe, vaapi_vld, 3840x2160, q=2-31, 200 kb/s, 24 fps, 24 tbn, 24 tbc (default)
    Metadata:
      encoder         : Lavc58.18.100 wrapped_avframe
frame=  240 fps=0.0 q=-0.0 Lsize=N/A time=00:00:10.00 bitrate=N/A speed=38.1x
video:126kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
Thanks @@frogger
Ok, next can we try the following :-
sudo /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format vaapi -i file:"/volume1/data/test/BigBuckBunny_2000hevc.mp4" -vf 'deinterlace_vaapi=rate=field:auto=1,scale_vaapi=w=640:h=360,hwdownload,format=nv12' -c:v libx264 -crf 20 file:"/volume1/data/test/BigBuckBunny_2000x264.mp4"
Best
- James
Metadata:
major_brand : iso4
minor_version : 1
Metadata:
Stream mapping:
Stream #0:0 -> #0:0 (hevc (native) -> h264 (libx264))
[libx264 @ 0x6f5140] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
[libx264 @ 0x6f5140] profile High, level 3.1
[libx264 @ 0x6f5140] 264 - core 155 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=-2 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=20.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, mp4, to 'file:/volume1/data/test/BigBuckBunny_2000x264.mp4':
Metadata:
major_brand : iso4
minor_version : 1
Stream #0:0(und): Video: h264 (libx264) (avc1 / 0x31637661), nv12, 640x360, q=-1--1, 48 fps, 12288 tbn, 48 tbc (default)
Metadata:
encoder : Lavc58.18.100 libx264
Side data:
cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
frame= 476 fps=0.0 q=-1.0 Lsize= 17kB time=00:00:09.89 bitrate= 14.1kbits/s speed=10.4x
video:11kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 59.926872%
[libx264 @ 0x6f5140] frame I:2 Avg QP: 6.50 size: 102
[libx264 @ 0x6f5140] frame P:120 Avg QP: 8.14 size: 28
[libx264 @ 0x6f5140] frame B:354 Avg QP:12.33 size: 19
[libx264 @ 0x6f5140] consecutive B-frames: 0.8% 0.0% 0.0% 99.2%
[libx264 @ 0x6f5140] mb I I16..4: 100.0% 0.0% 0.0%
[libx264 @ 0x6f5140] mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0.0% skip:100.0%
[libx264 @ 0x6f5140] mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0%
[libx264 @ 0x6f5140] 8x8 transform intra:0.0%
[libx264 @ 0x6f5140] coded y,uvDC,uvAC intra: 0.0% 0.1% 0.0% inter: 0.0% 0.0% 0.0%
[libx264 @ 0x6f5140] i16 v,h,dc,p: 96% 0% 4% 0%
[libx264 @ 0x6f5140] i8c dc,h,v,p: 100% 0% 0% 0%
[libx264 @ 0x6f5140] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 0x6f5140] kb/s:8.28
Thanks @@frogger - sorry, forgot to add can you make sure the file generated (/volume1/data/test/BigBuckBunny_2000x264.mp4) can be played and looks correct.
Best
- James
@@solabc16 - resulting file is only 17.1kB and playback is all green for 10 seconds
Hi @@frogger - ok, that's good (well, as far as troubleshooting goes) and likely explains why the 'mpegts' output fails.
@solabc16 would it be helpful to you to have access to the testbox?
If this is possible, that'd be awesome and much appreciated - feel free to PM me with details.
Best
- James
...and another test, can you check the output file again as well please:-
sudo /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -vaapi_device /dev/dri/renderD128 -i file:"/volume1/data/test/BigBuckBunny_2000hevc.mp4" -vf 'format=nv12,hwupload' -c:v h264_vaapi -qp 18 file:"/volume1/data/test/BigBuckBunny_2000x264.mp4"
Best
- James
@@solabc16 - didn't work, size is 262byte
  Metadata:
    major_brand     : iso4
    minor_version   : 1
    Metadata:
File 'file:/volume1/data/test/BigBuckBunny_2000x264.mp4' already exists. Overwrite ? [y/N] y
Stream mapping:
  Stream #0:0 -> #0:0 (hevc (native) -> h264 (h264_vaapi))
  Metadata:
    major_brand     : iso4
    minor_version   : 1
    Stream #0:0(und): Video: h264 (h264_vaapi) (High) (avc1 / 0x31637661), vaapi_vld, 3840x2160, q=0-31, 24 fps, 12288 tbn, 24 tbc (default)
    Metadata:
      encoder         : Lavc58.18.100 h264_vaapi
frame=  240 fps= 42 q=-0.0 Lsize=       0kB time=00:00:09.91 bitrate=   0.2kbits/s speed=1.74x
video:0kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
@@solabc16, I've been digging through the Xpenology log files once again I've noticed the following lines in the dmesg log:
[   25.740919] [drm] GPU HANG: ecode 9:0:0xfffffffe, reason: hang on rcs0, bcs0, vcs0, vecs0, action: reset
[   25.740954] i915 0000:00:02.0: Resetting rcs0 for hang on rcs0, bcs0, vcs0, vecs0
[   25.741106] i915 0000:00:02.0: Resetting bcs0 for hang on rcs0, bcs0, vcs0, vecs0
[   25.741281] i915 0000:00:02.0: Resetting vcs0 for hang on rcs0, bcs0, vcs0, vecs0
[   25.741415] i915 0000:00:02.0: Resetting vecs0 for hang on rcs0, bcs0, vcs0, vecs0
[   31.736837] i915 0000:00:02.0: Resetting chip for hang on rcs0, bcs0, vcs0, vecs0
[   31.736868] i915 0000:00:02.0: GPU recovery failed
[   31.752936] [drm] Initialized i915 1.6.0 20180514 for 0000:00:02.0 on minor 0
[   31.754027] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   31.754647] acpi device:54: registered as cooling_device4
[   31.754728] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input1
[   31.783390] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
So the GPU is haning, resetting and then fails to recover and yet it gets initialized and /dev/dri/ gets populated.
The Ubuntu dmesg log shows no such resetting attempts.
I've found some alleged workaround for similar errors by setting kernel parameter in grub.cfg (i915.modeset=1 i915.enable_rc6=0, etc.) but none of those worked so far.
Since I can't find any complete documentation on what they mean to control, I've started looking at the kernel source and the i915 implementation comparing them between kernel 4.4.59 (DS918+) and 4.15.0 (Ubuntu 18.04 Live). Maybe there's some undocumented setting that helps...
  • 2 weeks later...
Is there anything new here?
Hi @@solabc16,
thanks for the update! I had some busy weeks at work myself.
I think I've made some progress in finding the cause of the issue and maybe a solution, though.
Like I said in my previous post, I started looking into the kernel sources and compared them between kernel Versions (i.e. the non-working Xpenology and the working Ubuntu version) and following the implementation across kernel modules. Which was demanding but enlightening!
To make a long story short, it boils down to how errors are handled by the "old" i915 driver and how this is influenced by GPU virtualization implementation (IOMMU).
So, I've strong indication that the transcoding issue is related to Intel's Virtualization Direct I/O.
From what I know, this should be disableable in the BIOS, but I didn't have time to confirm this on the board yet.
  • 1 month later...
solabc16
Hello @@frogger
Thanks for the above, did you manage to identify whether or not it was 'Virtualization Direct I/O' support causing the issue?
Best
- James
Hi @@solabc16,
yes, I can confirm that disabling vd-t (Virtualization Direct I/O) in the bios settings resolves the issue.
Thank you all for your help to narrow it down to this! :)
Best
- F
solabc16
Thanks for the update @@frogger, appreciated - great to hear that solved it.
I'm sure this will help a number of other users, as this is likely to be the default setting on many systems.
Best
- James
