fbrassin 47 Posted January 15, 2019 Posted January 15, 2019 Hello, I use Chrome, when i connect to www.app.emby.media i cannot connect to my server if i don't click on "load unsecure script" before clicking on connect. Is there a way to tell chrome to load that script by default or make it secure? Tnx
fbrassin 47 Posted January 16, 2019 Author Posted January 16, 2019 I have 2 servers on 1 i have ssl enabled on the other not. But that message come to out as soon as i go in https://www.app.emby.media/ before logging in. I also tried with edge and it tell me "the site is not secure" and also "certificate error" (traslated by me from italian)
Luke 42242 Posted January 16, 2019 Posted January 16, 2019 Using the https url you will not be able to connect to your server over http. It will need to have ssl. Does that answer your question?
fbrassin 47 Posted January 17, 2019 Author Posted January 17, 2019 Now i've set ssl on my server and i can connect.
