paulmorabi 3 Posted January 15, 2019 Posted January 15, 2019 Hi, Now that we are approaching the stable release of Emby 4.0, is there a simple way to swtich within Kodi from beta to stable version of the plugin? If I unintall the beta repository will this pull future stable updates from the stable repository or do I need to reinstall?
Angelblue05 4132 Posted January 15, 2019 Posted January 15, 2019 You'd have to wait for the new stable version of the add-on to do that. Then yes, you can uninstall the beta repo and install the stable one to remain on the stable version. You should be set. 1
