B3rt 8 Posted January 18, 2019 Posted January 18, 2019 i will do this to night, currently i am at work. 1
pand0ra 3 Posted January 18, 2019 Posted January 18, 2019 i will do this to night, currently i am at work. Great job!!
B3rt 8 Posted January 18, 2019 Posted January 18, 2019 not working.. not happy with this update I have 2 kodi clients (both libreelec) and now both are not working. I updated the file and now i get an error that kodi cannot connect to the server. Have now a server where 2 kodi clients cannot connect to, think i have to switch to Plesk if it is not possible to get kodi back online again..... kodi.log
EvolutionVII 2 Posted January 18, 2019 Posted January 18, 2019 Yes, the hard reset seems to be the only way. Thanks for reporting back to confirm this resolved your issue. By the way, what is the issue with your Android box? Did you make a thread? The issue with my second box was that I was running 2 versions of kodi at the same time and that caused the webserver to fail at startup. I just came back from my mothers appartement where I had to do a db reset on 3 androidboxes and they all worked fine after a fresh db update. 1
B3rt 8 Posted January 18, 2019 Posted January 18, 2019 hmmm nowsuddenly since i use this update i crashes my emby server, that is why it cannot connect. The emby server is indeed totattly unreachable, the service on my nas is running but the web interface is dead. I restarted the service and emby was online again, as soon as i try something on kodi the server is down again
Luke 42239 Posted January 18, 2019 Posted January 18, 2019 hmmm nowsuddenly since i use this update i crashes my emby server, that is why it cannot connect. The emby server is indeed totattly unreachable, the service on my nas is running but the web interface is dead. I restarted the service and emby was online again, as soon as i try something on kodi the server is down again Server log?
Angelblue05 4132 Posted January 18, 2019 Posted January 18, 2019 not working.. not happy with this update I have 2 kodi clients (both libreelec) and now both are not working. I updated the file and now i get an error that kodi cannot connect to the server. Have now a server where 2 kodi clients cannot connect to, think i have to switch to Plesk if it is not possible to get kodi back online again..... I will have a look at your log in a bit.
Angelblue05 4132 Posted January 18, 2019 Posted January 18, 2019 @@B3rt According to your log, the add-on loaded. That's good, but it couldn't reach your server. Are you able to provide an updated Kodi log and server log? We'd really like to get to the bottom of this. In reply to your previous post. just so you are aware. This project is not brought to you by the Emby team, but by myself with help of Sualfred who are just Emby users like you are. We work on Emby for Kodi in our free time. The project is free. I understand the situation can be frustrating, but we are not being paid for this and don't have to provide support in any way. But I'd like to believe we are dedicated people, so here we are, ready to help you. Remember that next time you bring up plex. 2
B3rt 8 Posted January 21, 2019 Posted January 21, 2019 0k noted that. I got finally 1 of the 2 kodi's to work. The server was indeed offline, it crashed due to the second kodi. I reinstalled the second kodi running on a raspberryPI 2 using librelec. After the reinstall i installed again emby stable, then installed the zip you gave earlier. But this emby will not start running, each time kodi is rebooted it ask again for a password. Also the system is very very slow when emby is installed, emby is scanning but crashes during scan and reboots kodi/raspPY After reboot everything starts again, i have to enter password, kodi is slow, emby is scanning/importing and after a while it reboots Note: it is a clean install, only kodi and emby is on it. 01_KODI.log 01_KODI_CRASH.log 1
Angelblue05 4132 Posted January 21, 2019 Posted January 21, 2019 @@B3rt Thanks for providing your log. Are you sure the add-on is installing on the second Kodi? I still see 3.0.34 running in your logs. Do you have the beta repository installed on your second Kodi? Maybe it's blocking due to being unable to install the dependencies? Let me know what you see on your side.
B3rt 8 Posted January 21, 2019 Posted January 21, 2019 yes, but it seems it does not install the new version. When i install the zip i get a message somthing like plugin dependency loaded but nothing happens, on my other kodi i got an other settings interface etc. This kodi stays the same, i installed it 3 times and eachtime kodi only reports the dependency message. 1
Angelblue05 4132 Posted January 21, 2019 Posted January 21, 2019 (edited) @@B3rt Grab the dependencies here if you don't want to install the beta repo. Install v0.13 http://kodi.emby.media/Public%20testing/Dependencies/beta/ Then install the build I gave you and it should work this time. In the future, those dependencies will no longer be required. But for now, I suggest to install the beta repo so you can keep up with the beta updates until stable is released. We are almost there. http://kodi.emby.media/ Edited January 21, 2019 by Angelblue05
Angelblue05 4132 Posted January 21, 2019 Posted January 21, 2019 Instead of the build I gave you earlier. You can grab the latest here, which also contain the fix from the build I gave you. Use the build here: 3.1.45a http://kodi.emby.media/Public%20testing/
B3rt 8 Posted January 21, 2019 Posted January 21, 2019 tried that also as first, but exactly the same. It seems kodi simply does not install/load the plugin, it just reports: blahblah update emby dependency (cannot read it, message is to long and there half visible and quickly gone) and then nothing happens, also not after a reboot.
B3rt 8 Posted January 22, 2019 Posted January 22, 2019 i made a quick photo what is displayed. Nothing happens after that message, after reboot i still have to login and it still reports i am using the old version
B3rt 8 Posted January 22, 2019 Posted January 22, 2019 here the log after i tried to install the zip kodi.log
Angelblue05 4132 Posted January 22, 2019 Posted January 22, 2019 I don’t get why it’s giving issues. But if you manually install from zip the dependencies I showed you, then it should work when you go to install 3.1.45 Let me know.
B3rt 8 Posted January 22, 2019 Posted January 22, 2019 what do you mean? I did install the zip manually, i downloaded it to my pc first, then uploaded it to kodi and then installed the zip. It errors with the dependency error; 00:03:09.191 T:1439691680 ERROR: CAddonInstallJob[plugin.video.emby]: De afhankelijkheid op plugin.video.emby.movies versie 0.13 kan niet worden voldaan. What should i install then? 1
Angelblue05 4132 Posted January 22, 2019 Posted January 22, 2019 (edited) what do you mean? I did install the zip manually, i downloaded it to my pc first, then uploaded it to kodi and then installed the zip. It errors with the dependency error; 00:03:09.191 T:1439691680 ERROR: CAddonInstallJob[plugin.video.emby]: De afhankelijkheid op plugin.video.emby.movies versie 0.13 kan niet worden voldaan. What should i install then? It's complaining 0.13 of plugin.video.emby.movies dependency is not installed. You install all 3 zips v0.13 here? http://kodi.emby.media/Public%20testing/Dependencies/beta/ If you did, go under Installed Addons > All > Scroll until you see Emby and the dependencies, then check the info on them, does it show version 0.13 for all 3 dependencies? This process is usually simple, I'm not sure why you are having difficulties, but let me know if you did install all 3 and all 3 are version 0.13 and it's still giving that error. That's definitely not normal and not something I've seen happen in the past. Edited January 22, 2019 by Angelblue05
B3rt 8 Posted January 22, 2019 Posted January 22, 2019 No, i installed after a clean install the repo (kodi.emby.media) and then emby, when emby was installed i then tried to load/install the zip you mentioned. On my other kodi i did the same, had nothing to do but installing from repo and the (correct) update zip
ebnerjoh 2 Posted February 17, 2019 Posted February 17, 2019 Hi, I have the same issue. Since I updated Emby Server to V4 my Sync stopped working on my Libreelc (on Odroid C2). I have then upgraded my Libreelec v17 to v18. I have removed Emby from Kodi and installed again via the beta channel, but I have always the same result - the first sync works, but after a restart I am getting an error on the sync. Emby Server: 4.0.2.0 LibreElec: 9.0.0 (Odroid_C2.arm) Emby Addon: 1.0.6 Br, Johannes
Angelblue05 4132 Posted February 17, 2019 Posted February 17, 2019 (edited) Repair your video libraries in Emby for Kodi. There was a change to the path system between Krypton and Leia. Edited February 17, 2019 by Angelblue05
ebnerjoh 2 Posted February 17, 2019 Posted February 17, 2019 Repair your video libraries in Emby for Kodi. There was a change to the path system between Krypton and Leia. I have tried this, also removing everything. As mentioned. The Initial Sync is working but then the sync stops working. Br, Johannes
