xnappo 1611 Posted March 8, 2015 Author Posted March 8, 2015 (edited) Please install the beta repo and install from there. Github doesn't but the zip in the exact right format. http://mediabrowser.tv/community/index.php?/topic/9984-kodi-beta-repo/ I am also uploading to the stable repo now. xnappo Edited March 8, 2015 by xnappo
monkeyslapper 11 Posted March 9, 2015 Posted March 9, 2015 This worked Like a Charm FANTASTIC! Thanks.. If I wanted to put some feed back on the Aeon Skin or suggestion what forum page would be best? Thanks Again. Monkeyslapper
xnappo 1611 Posted March 9, 2015 Author Posted March 9, 2015 (edited) This one please. I do know it is quite lacking compared to the other MB3 skins - I am not nearly as versed in skin coding. Edited March 9, 2015 by xnappo
achaw 1 Posted April 1, 2015 Posted April 1, 2015 (edited) Aleatory fanart background via "Skin Widgets" not working on home screen, right? I get black screen... Using latest Kodi and latest skin version via beta repo. BTW, amazing skin, i love v4 of Aeon, thanks Edited April 1, 2015 by achaw
xnappo 1611 Posted April 2, 2015 Author Posted April 2, 2015 Honestly - with the new Emby for Kodi there will not be any more releases of this. With Emby for Kodi everything will work like the native skin. Not saying you should switch now - as we are in beta and it is not production worthy... xnappo
dark_slayer 103 Posted April 2, 2015 Posted April 2, 2015 For the native skins in Helix I think the best nox mods are Aeon Nox Silvo for 5 and XBMCMania for Nox 4
ratzofftoya 0 Posted May 22, 2015 Posted May 22, 2015 So, just to be sure I have this correct, if I want to use Shednox with Emby 4 Kodi (rather than XBMB3C), I just install the Shednox skin per the instructions on the Kodi forum, then install the Emby for Kodi add-on from the beta repo, right? I don't have to install the modified Shednox from the Emby repo unless I'm using XBMB3C? Or am I misunderstanding?
Angelblue05 4132 Posted May 22, 2015 Posted May 22, 2015 So, just to be sure I have this correct, if I want to use Shednox with Emby 4 Kodi (rather than XBMB3C), I just install the Shednox skin per the instructions on the Kodi forum, then install the Emby for Kodi add-on from the beta repo, right? I don't have to install the modified Shednox from the Emby repo unless I'm using XBMB3C? Correct.
xnappo 1611 Posted May 22, 2015 Author Posted May 22, 2015 Right - this mod isn't needed anymore. xnappo
