Amadeyo 0 Posted January 14, 2019 Posted January 14, 2019 So I'm using m3u8-links provided by the swedish broadcaster. It won't work in Emby, nothing will appear... I've tried all, setting different User Agents, force connection and tried limit to "1". But nothing happeneds, I'm on latest beta, I've got Emby premiere and I'm not super novice nor hyper advanced Anyone know what to do ? Kind regards Amadeyo
Luke 42245 Posted January 14, 2019 Posted January 14, 2019 Hi there, welcome. Please attach the information requested in how to report a media playback issue. thanks !
Luke 42245 Posted January 14, 2019 Posted January 14, 2019 What are the contents of the m3u8 url that you entered? Is it a channel listing?
Amadeyo 0 Posted January 14, 2019 Author Posted January 14, 2019 (edited) The link will open a live stream from SVT. Can't you open it ? Edited January 14, 2019 by Amadeyo
Luke 42245 Posted January 14, 2019 Posted January 14, 2019 I can't open it, it says access denied, probably due to region blocking. Anyway you can't enter a single live stream there, it has to be an m3u channel listing, which you can learn about on our live tv wiki: https://github.com/MediaBrowser/Wiki/wiki/Live-TV For just a single live stream, the IPTV plugin is probably a better fit.
Amadeyo 0 Posted January 14, 2019 Author Posted January 14, 2019 I will try that and report back, thanks for the quick support!
