mwkurt 5 Posted January 13, 2019 Posted January 13, 2019 Hello folks, Hoping someone has an answer and can help me out. I am using VAP to post process my recorded video files for commercial detection and deletion. Problem is I have to move the TS files by hand because VAP can not monitor subdirectories. Does anyone have a batch file or can tell me what they use to monitor and move completed TS video files a a specific directory? Thanks! Mark
mwkurt 5 Posted January 14, 2019 Author Posted January 14, 2019 What is vap? https://videoredo.net/msgBoard/index.php?threads/videoredo-autoprocessor-program.16340/
Luke 42244 Posted January 14, 2019 Posted January 14, 2019 Ok. @@CBers may have some post processing tips.
CBers 7554 Posted January 14, 2019 Posted January 14, 2019 Ok. @@CBers may have some post processing tips. Nope, other than this.
Carlo 4561 Posted January 18, 2019 Posted January 18, 2019 Why not just use the post processing facilities built into Emby to move the file into a directory that VAP can monitor?
Luke 42244 Posted January 18, 2019 Posted January 18, 2019 Why not just use the post processing facilities built into Emby to move the file into a directory that VAP can monitor? Yes that is possible.
mwkurt 5 Posted January 23, 2019 Author Posted January 23, 2019 Why not just use the post processing facilities built into Emby to move the file into a directory that VAP can monitor? Sounds interesting! Where can I find out more information about how to do this? I do not see a "post processing" entry in the Wiki. Thanks, Mark
Luke 42244 Posted January 23, 2019 Posted January 23, 2019 Well no, you would have to write your own application or script to do that work. The Emby post processor can then launch your script or application. You can learn more on our Live TV wiki: https://github.com/MediaBrowser/Wiki/wiki/Live-TV Please let us know if this helps. Thanks !
PenkethBoy 2068 Posted January 23, 2019 Posted January 23, 2019 @@mwkurt The wiki does not contain anything on PP but see the link Cbers provided above to get you started on how to use a PP script The notes i wrote will give you an explanation of what it does etc It does not move the finished file (as it saves it alongside the original) - but you can easily change this 1
mwkurt 5 Posted January 23, 2019 Author Posted January 23, 2019 Yeah....I know nothing about running scripts. Thanks anyway, Mark
