Rogero54 0 Posted January 13, 2019 Posted January 13, 2019 Loaded the beta to get the Emby Guide data. Currently using MCE and it has a guide feature that is missing in Emby. Would be nice if you could scrool to far left and then have a filter screen so you could look for only sports, or movies or HD content like MCE does.
ebr 16338 Posted January 13, 2019 Posted January 13, 2019 Hi. The web app does have filters for basic content types. Click '...' menu.
Rogero54 0 Posted January 13, 2019 Author Posted January 13, 2019 It doesn't work on the Shield. even if it did exist on the shield, the implementation is not very usable. It requires that you scroll all the way to the top of the guide to click on the ... 's. MCE allows you to go left anywhere in the guide to activate the filters.
ebr 16338 Posted January 13, 2019 Posted January 13, 2019 It doesn't work on the Shield. even if it did exist on the shield, the implementation is not very usable. It requires that you scroll all the way to the top of the guide to click on the ... 's. MCE allows you to go left anywhere in the guide to activate the filters. No, this is not implemented in that app at this time. However, you can quickly access the toolbar by hitting back, up on your remote.
Spaceboy 2573 Posted January 14, 2019 Posted January 14, 2019 I was just thinking this at the weekend. Surely one of the easiest live tv improvements that could be made would be for emby to support the fairly common notion of channel groups and, 2nd, provide the filter in the live TV guide by moving left when you are already at time 0. Just like wmc did
