Luke 42238 Posted February 13, 2019 Posted February 13, 2019 @@martincom, that's interesting, thanks for the info. We'll look into these findings.
mi7chy 0 Posted February 18, 2019 Posted February 18, 2019 (edited) Also have issue with Emby DLNA dying consistently every day and having exit and rerun Emby server to get DLNA working again. This is the portable version of Emby 4.0.1.0 on Windows 10 Pro x64 IPv4 only that's been auto updated to 4.0.2.0. No problem with Emby HTTP. Edited February 18, 2019 by mi7chy
Luke 42238 Posted February 19, 2019 Posted February 19, 2019 Also have issue with Emby DLNA dying consistently every day and having exit and rerun Emby server to get DLNA working again. This is the portable version of Emby 4.0.1.0 on Windows 10 Pro x64 IPv4 only that's been auto updated to 4.0.2.0. No problem with Emby HTTP. Hi, what do you mean exactly?
mi7chy 0 Posted February 19, 2019 Posted February 19, 2019 Hi, what do you mean exactly? Emby DLNA service dies consistently when checked every day trying to access from DLNA client like Kodi. Someone mentioned IPv6 as a possible cause but I'm only running IPv4. Restarting Emby from task bar icon most of the time doesn't resolve the issue and have to fully exit Emby and relaunch. When this happens Emby app via HTTP still works so it's just Emby DLNA service that's affected.
Luke 42238 Posted February 19, 2019 Posted February 19, 2019 You could try lowering the alive message interval in dlna settings. Currently it is every 30 minutes. You could try setting it to 10 or 5 minutes.
mi7chy 0 Posted February 19, 2019 Posted February 19, 2019 You could try lowering the alive message interval in dlna settings. Currently it is every 30 minutes. You could try setting it to 10 or 5 minutes. Currently have it at 15 secs and it's still not as reliable as, for example, Windows 10 built-in DLNA support that worked 100% of the time before removing the service to try Ember or BubbleUPnP on mobile devices. Will try an even lower interval like 5 secs. Thanks.
Luke 42238 Posted February 19, 2019 Posted February 19, 2019 No, I wouldn't do that, that will just spam messages over the network. Even what you have now is far too much. You may want to check windows firewall to make sure that udp traffic is allowed for the server.
nevolex 4 Posted February 26, 2019 Posted February 26, 2019 I am having similar issues, emby dlna server is not always showing. Sometimes it takes up to 30 secs to show up or so, sometimes never, sometimes nearly immediately. BubbleUPnP cannot event detect it at all. Thanks
martincom 29 Posted February 26, 2019 Posted February 26, 2019 I am having similar issues, emby dlna server is not always showing. Sometimes it takes up to 30 secs to show up or so, sometimes never, sometimes nearly immediately. BubbleUPnP cannot event detect it at all. Thanks Your symptoms are identical to what I was experiencing. Did you make the checks I set forth in post #25 of this thread? 1
nevolex 4 Posted February 26, 2019 Posted February 26, 2019 Your symptoms are identical to what I was experiencing. Did you make the checks I set forth in post #25 of this thread? Thank you for the advice but I don't have a Roku player to test it on. Not sure why BubbleUPnP just cannot see it at all no matter what I do in the settings.
martincom 29 Posted February 26, 2019 Posted February 26, 2019 Thank you for the advice but I don't have a Roku player to test it on. Not sure why BubbleUPnP just cannot see it at all no matter what I do in the settings. I'm not familiar with BubbleUPnP. Is it a device or an application? Regardless, I would think there would be some mechanism whereas you could determine what IP address(es) are being assigned to it and likewise with the PC hosting Emby. If either device is being assigned both a IPv4 and a IPv6 address, disable the IPv6 functionality on both and see if the problem persists. 1
Luke 42238 Posted February 26, 2019 Posted February 26, 2019 I am having similar issues, emby dlna server is not always showing. Sometimes it takes up to 30 secs to show up or so, sometimes never, sometimes nearly immediately. BubbleUPnP cannot event detect it at all. Thanks We are looking into improving this for the next release. Thanks.
nevolex 4 Posted February 26, 2019 Posted February 26, 2019 It is on of the most popular DLNA players/server for android platform I'm not familiar with BubbleUPnP. Is it a device or an application? Regardless, I would think there would be some mechanism whereas you could determine what IP address(es) are being assigned to it and likewise with the PC hosting Emby. If either device is being assigned both a IPv4 and a IPv6 address, disable the IPv6 functionality on both and see if the problem persists. Thank you, Luke We are looking into improving this for the next release. Thanks.
mi7chy 0 Posted March 22, 2019 Posted March 22, 2019 Blasting alive messages interval at 5 sec interval is working so far but looking forward to update since, for example, BubbleUPnP doesn't require this option to work.
Ninko 78 Posted April 4, 2019 Author Posted April 4, 2019 Is this DLNA ever likely going to be fixed soon?
Ninko 78 Posted April 22, 2019 Author Posted April 22, 2019 Ever since the last update, DLNA seems even worse, it doesn't even show up on my phone anymore when it mainly use to! Seeing as DLNA is meant to be a standard protocol, I don't understand why it's been so badly implemented into Emby?
Luke 42238 Posted April 22, 2019 Posted April 22, 2019 Ever since the last update, DLNA seems even worse, it doesn't even show up on my phone anymore when it mainly use to! Seeing as DLNA is meant to be a standard protocol, I don't understand why it's been so badly implemented into Emby? It's meant to be a standard but is implemented differently on many devices, therefore it has to be tested individually on every device you want to support. Please attach the information requested in how to report a problem. thanks.
Luke 42238 Posted April 22, 2019 Posted April 22, 2019 Log attached What mobile app is the dlna server not showing up with?
lfjelsson 0 Posted April 26, 2019 Posted April 26, 2019 hi there i have a similar problem with ps4 dlna subsystem
