Luke 42241 Posted January 20, 2019 Posted January 20, 2019 What about music files, how do they compare?
zsoltsuhajda 4 Posted January 20, 2019 Author Posted January 20, 2019 I can't say anything about music files, I use Spotify for music.
Godfather67 0 Posted January 20, 2019 Posted January 20, 2019 Hi there, how have you configured your sound settings in the app? Can you please go over an example? thanks ! Here is the settings from Win10 app: And here is movie example: Stat:
Godfather67 0 Posted January 26, 2019 Posted January 26, 2019 The issues still pending after upgrade to 4.0.1.
Luke 42241 Posted January 26, 2019 Posted January 26, 2019 Have you configured windows sound settings?
zsoltsuhajda 4 Posted January 26, 2019 Author Posted January 26, 2019 We are still talking about xbox issues, what to configure in windows sound settings? This is a 2 page long conversation where Godfather67 and me described our settings 2 times, and there is no solution. Should we write down again?
Luke 42241 Posted January 26, 2019 Posted January 26, 2019 He also mentioned windows so that is why I asked.
Godfather67 0 Posted January 27, 2019 Posted January 27, 2019 (edited) He also mentioned windows so that is why I asked. Yes i mentioned Windows too, but my main platform is Emby Theater on Xbox One S. No sound on it at various movies if i choose Dolby Digital audio track. There should be a problem with Emby Theater Dolby decoding, because if I play movies via Web interface, using Chrome on Win10, i get sound for both audio track. Android and IOS clients works perfectly too, as I mentioned earlier. Edited January 27, 2019 by Godfather67
blumamba 10 Posted January 27, 2019 Posted January 27, 2019 Right, but windows audio needs be configured. And if you have the video open in the browser at the same time, it will stop the app accessing the audio device. So I was was trying to create a baseline. Close all apps, make sure your audio device is configured and then play only in the Emby app. And I suggest using the desktop app, not the store app. on the pc you have to use the theater app and NOT the store app as you stated. Check your audio output settings on the pc and make sure they are set to 2.0 or you will have issues. After you confirm the audio is on the pc set to 2.0 install the client app and set the audio as needed. Hope that helps.
Godfather67 0 Posted January 28, 2019 Posted January 28, 2019 (edited) on the pc you have to use the theater app and NOT the store app as you stated. Check your audio output settings on the pc and make sure they are set to 2.0 or you will have issues. After you confirm the audio is on the pc set to 2.0 install the client app and set the audio as needed. Hope that helps. Thanks for your answer, but it won't solve the original issue on Xbox One. I just quoted the store app on Win10, because the problem can be reproduced with that, as it is exists on Xbox One! Edited January 28, 2019 by Godfather67
Luke 42241 Posted January 28, 2019 Posted January 28, 2019 I vaguely recall this reported from another xbox user a while ago and after investigation they found that they had somehow muted the volume of the emby app and they were able to correct it in xbox system settings. That may or may not be your issue but mentioning it just in case.
zsoltsuhajda 4 Posted January 30, 2019 Author Posted January 30, 2019 I have audio in certain movies, so muting cannot be the problem.
Godfather67 0 Posted January 30, 2019 Posted January 30, 2019 I vaguely recall this reported from another xbox user a while ago and after investigation they found that they had somehow muted the volume of the emby app and they were able to correct it in xbox system settings. That may or may not be your issue but mentioning it just in case. Negative, I have audio when i choose the English DTS audio track on the sampled movie, and no sound, when i switched to Hungarian DD 5.1.
zsoltsuhajda 4 Posted February 14, 2019 Author Posted February 14, 2019 I would really love to have a solution for this to make any sense of purchased emby premiere. 1
Godfather67 0 Posted February 14, 2019 Posted February 14, 2019 I can only join the previous speaker, as an Emby premier user.
Luke 42241 Posted February 14, 2019 Posted February 14, 2019 Have you configured windows sound settings?
zsoltsuhajda 4 Posted February 14, 2019 Author Posted February 14, 2019 Guide me please what to set in windows. My server is on Windows Server 2019, client is xbox one.
Luke 42241 Posted February 14, 2019 Posted February 14, 2019 In that case, have you configured Xbox One sound settings?
zsoltsuhajda 4 Posted February 14, 2019 Author Posted February 14, 2019 Xbox hdmi jbl bar 3.1 hdmi arc panasonic viera Xbox audio setup: HDMI audio: Bitstream out Optical audio: off Bitstream format: Dolby digital 5.1
Guest asrequested Posted February 14, 2019 Posted February 14, 2019 If you turn bitstreaming off, do you get sound?
zsoltsuhajda 4 Posted February 14, 2019 Author Posted February 14, 2019 Tried all available settings, the only app where I don't have audio is emby theater
zsoltsuhajda 4 Posted February 15, 2019 Author Posted February 15, 2019 We are in an infinite loop with these questions. I don't have audio problems at all, except Emby Theater app. And this is the 4th time I wrote this down here. 1
