MischaBoender 5 Posted January 14, 2019 Posted January 14, 2019 Kodi RC5 get stuck on migration, reverting to RC4 fixes it I would really appreciate if you could share how you reverted to RC4.
jh30uk 5 Posted January 14, 2019 Posted January 14, 2019 (edited) I did as bellow again but this time fully uninstalled Kodi RC5 and fresh installed RC4 then before its initial run I renamed my Config back to its proper name and all my Emby settings were retained. https://emby.media/community/index.php?/topic/67795-beware-if-you-update-to-new-kodi-18-rc5/ Edited January 15, 2019 by jh30uk
Angelblue05 4132 Posted January 17, 2019 Posted January 17, 2019 (edited) I believe the re-prompt is fully resolved with 3.1.44. Edited January 17, 2019 by Angelblue05
jh30uk 5 Posted January 17, 2019 Posted January 17, 2019 (edited) Wrong Topic soz Edited January 17, 2019 by jh30uk
Angelblue05 4132 Posted January 17, 2019 Posted January 17, 2019 @@jh30uk Just to clarify your situation, it's an issue with the migration of the database when you've updated Kodi?
jh30uk 5 Posted January 17, 2019 Posted January 17, 2019 (edited) YES! I removed my above post as the email notification took me here and topic was not what I thought it was due to my post to peep above. I prefer Kodi+Emby TBH but have the same issues as others with Library not updating or remembering Next Up to play after a restart of Kodi and the Kodi 18 RC 5 and RC 5.2 builds not liking Emby and sticking at migration which may be the Skin. Emby android TV app has same issue ok Next Up so serber is my issue. I would also like the Server and Android TV app to not list new shows added to be in next Up as I have not started to watch them and may not for a very long time, Emby Kodi does not do this so that is fine. Edited January 17, 2019 by jh30uk
Angelblue05 4132 Posted January 17, 2019 Posted January 17, 2019 (edited) It's not something I've experienced, I'm also on RC5.2. What if you disable Emby, stop Kodi, start Kodi. Does it allow the migration to complete? Edited January 17, 2019 by Angelblue05
jh30uk 5 Posted January 17, 2019 Posted January 17, 2019 Nope it will never migrate or even show MSG again, I have to kill the Kodi as it cannot exit. I had to redo RC4 and will again later tonight.
Angelblue05 4132 Posted January 17, 2019 Posted January 17, 2019 (edited) So then it's not an issue with Emby for Kodi? If the add-on is disabled and it still happens? Have you tried to delete MyVideos116.db while also having Emby for Kodi disabled and then starting Kodi? Edited January 17, 2019 by Angelblue05
jh30uk 5 Posted January 17, 2019 Posted January 17, 2019 (edited) Yes I tried deleting .db's and other results on Google, I am using only Emby on Kodi no other plug-ins other than what Emby installs and as you know Emby becomes the Skin for Kodi so I cannot run Kodi to disable anything. EDIT : Just redid RC4 renamed my Config and all working then reverted Skin to Kodi default and disabled all Emby Plug-ins that it would let me then upgraded to RC 5.2 and stuck again. Edited January 17, 2019 by jh30uk
