swindmiller 5 Posted April 27, 2014 Posted April 27, 2014 Sorry if this was discussed...I did some searching. Can you resume between clients? For example, I was watching Iron Man (got half way thru), stopped it and wanted to resume watching thru the website. It did not have the resume option and started playing from the beginning. I went back to the MBC client I was watching from and it resumed. It appears I can resume from the MBC client and the website but only if I originated playing from that same client I want to resume from. Just curious if this is how it works or if I am doing something wrong. Thanks, Scott
Luke 42244 Posted April 27, 2014 Posted April 27, 2014 You can resume between clients. What probably happened is one of the failed to record your position when you stopped. Next time it happens, post your server log and we'll see if we can figure it out.
swindmiller 5 Posted April 27, 2014 Author Posted April 27, 2014 Thanks. I just played Man of Steel for a little over 5 minutes on my HTPC running MBC. I stopped it and saw the resume option there. I went to the web client and did not have the resume option...it played from the beginning. Here is my log (had to zip it, was too big)....thanks for looking. server-63534080700.zip
Luke 42244 Posted April 27, 2014 Posted April 27, 2014 did you refresh the page in the browser or was it already open?
swindmiller 5 Posted April 27, 2014 Author Posted April 27, 2014 It wasn't open...but I tried to refresh anyway and it did not help
swindmiller 5 Posted April 27, 2014 Author Posted April 27, 2014 I should also mention that I use Media Center Master for all of the Metadata. I have all the options turned off in MB3. I haven't switched over to just using MB3 for fetching. However all of the metadata is shown in media browser (time, media info, etc) I don't know if that matters.
Luke 42244 Posted April 27, 2014 Posted April 27, 2014 well can anyone else reproduce? there's no obvious issue in the log there.
swindmiller 5 Posted April 27, 2014 Author Posted April 27, 2014 I thought maybe it had something to do with my metadata or the way I had it setup. Thanks for verifying my log looks ok. Anything I can try?
swindmiller 5 Posted June 27, 2014 Author Posted June 27, 2014 *SIGH*, I figured it out It only carries over per user. That makes perfect sense but just did not click with me. I have different accounts setup for showing only certain videos and one main account to show everything. My mistake Thanks for everyone who tried to help...sorry if I wasted your time.
swindmiller 5 Posted June 28, 2014 Author Posted June 28, 2014 Sorry to rehash this but I am still having the same problem...even after multiple server updates, so it must be something with my Metadata or something else in my setup. To sum up....I can resume fine from within MBC installed on several Media Center pc's throughout the house, starting on one PC and picking it up on another and I can also resume from the website. What I cannot do it start something on my PC thru MBC and resume it thru the website, I never get the option yet I have the option from within MBC. I checked my logs and even posted them earlier but don't really know what to look for. What I did notice was when I start a movie thru MBC (Direct Play) it does not show up in the log, I assume that is ok. Is there a file or something stored showing where the video should resume from? Maybe a permissions issue? Thanks! I would love to get this working. Scott
Koleckai Silvestri 1154 Posted June 28, 2014 Posted June 28, 2014 (edited) Some clients are supposed to have "also here" functionality and you can tag multiple users. Not sure which ones support it yet. Edited June 28, 2014 by Wayne Luke
ab123ga 18 Posted June 28, 2014 Posted June 28, 2014 Have you checked the percentage watched to be resumable? I changed my value to 1% and that makes most movies resumable. I just tested on a "charlie brown" cartoon that is 1440 seconds long. 1% is 14 seconds. I started in android. It was resumable via MBC, the web, and even back on android.
swindmiller 5 Posted June 28, 2014 Author Posted June 28, 2014 Some clients are supposed to have "also here" functionality and you can tag multiple users. Not sure which ones support it yet. Sorry I don't understand the "almost there" feature...is there somewhere that I can read about it? Thanks, Scott
BATTLE DONKEY 98 Posted June 28, 2014 Posted June 28, 2014 Sorry I don't understand the "almost there" feature...is there somewhere that I can read about it? Thanks, Scott "Also here" is for some clients like MediaBrowser Classic. If u click on the user icon it allows u to specify other users who are "also there" with u watching the movie so the resume and watched status will carry over to their user accounts also
swindmiller 5 Posted June 30, 2014 Author Posted June 30, 2014 I never noticed that option before. Is there a way to make that option stick? It seems to only stay checked for that session. Thanks, Scott
