jathe 9 Posted January 9, 2019 Posted January 9, 2019 I tryied to add a M3u channel to my Live tv, but i got this error NO COMPATIBLE STREAMS AT THIS MOMENT, PLEASE CONTACT YOUR ADMIN the log of my emby server is: DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzcxLjAuMzU3OC45OCBTYWZhcmkvNTM3LjM2fDE1NDY4NTA2ODI1MDA1&MediaSourceId=56a2098f7d114f53f7e0962d9c7ca956&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=79808000&AudioBitrate=192000&PlaySessionId=cf29d8cadf2943558d993cba731d225f&api_key=de8ba24c94a34db1ba4a8d95271b14d6&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_56a2098f7d114f53f7e0962d9c7ca956&AudioStreamIndex=-1&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=51&TranscodeReasons=ContainerNotSupported&allowVideoStreamCopy=false&allowAudioStreamCopy=false{"Protocol":"Http","Id":"56a2098f7d114f53f7e0962d9c7ca956","Path":"http://189.203.173.21/LIVE/H01/CANAL111/PROFILE05.m3u8","Type":"Default","IsRemote":true,"ReadAtNativeFramerate":false,"DiscardCorruptPts":true,"FillWallClockDts":true,"IgnoreDts":false,"IgnoreIndex":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_56a2098f7d114f53f7e0962d9c7ca956","RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"VideoRange":"SDR","DisplayTitle":"","IsInterlaced":true,"BitRate":20000000,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"DisplayTitle":"","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"Formats":[],"Bitrate":20000000,"RequiredHttpHeaders":{"User-Agent":"VLC/3.0.1"},"AnalyzeDurationMs":3000}User policy for Jathe: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: TrueAffected codecs:>>>>>> libx264 Software EncoderColor Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10LE, YUV422P10LE, YUV444P10LE, NV20LEProfiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Profile (Level 6.2)>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 0Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0)Info Encoder supports input streamInfo FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder'>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 0Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0)Info Encoder supports input streamInfo FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder'/opt/emby-server/bin/ffmpeg -analyzeduration 3000000 -user_agent "VLC/3.0.1" -fflags +discardcorruptts+fillwallclockdts -i "http://189.203.173.21/LIVE/H01/CANAL111/PROFILE05.m3u8"-map_metadata -1 -map_chapters -1 -threads 0 -sn -c:v:0 libx264 -pix_fmt yuv420p -maxrate 20000000 -bufsize 40000000 -preset veryfast -profile high -level 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:gte(t,n_forced*3)" -vf "yadif=0:-1:0" -vsync -1 -codec:a:0 libmp3lame -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_list_entry_prefix "hls/8465488d0db56898e86f33c394aa6d9f/" -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/lib/emby/transcoding-temp/8465488d0db56898e86f33c394aa6d9f.m3u8" -y "/var/lib/emby/transcoding-temp/8465488d0db56898e86f33c394aa6d9f%d.ts" ffmpeg version 4.0.2-emby_2018_12_09 Copyright © 2000-2018 the FFmpeg developersbuilt with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0)configuration: --cc=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-vdpau --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-libsmbclient --enable-cuda --enable-cuvid --enable-libmfx --enable-nvenc --enable-vaapi --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --extra-libs='-lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -luuid -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-staticlibavutil 56. 14.100 / 56. 14.100libavcodec 58. 18.100 / 58. 18.100libavformat 58. 12.100 / 58. 12.100libavdevice 58. 3.100 / 58. 3.100libavfilter 7. 16.100 / 7. 16.100libswscale 5. 1.100 / 5. 1.100libswresample 3. 1.100 / 3. 1.100libpostproc 55. 1.100 / 55. 1.100[http @ 0x1b82700] HTTP error 404 Not Foundhttp://189.203.173.21/LIVE/H01/CANAL111/PROFILE05.m3u8:Server returned 404 Not Found the channel url is working fine, you can check on any browser http://189.203.173.21/LIVE/H01/CANAL111/PROFILE05.m3u8 thanks in advance
samuelqwe 317 Posted January 9, 2019 Posted January 9, 2019 When I try your link, it leads to “404 not found”. It is exactly as Emby is reporting in the log.
jathe 9 Posted January 9, 2019 Author Posted January 9, 2019 I change the host for the IP, the host is: http://sl.cdn.iutpcdn.com/LIVE/H01/CANAL107/PROFILE05.m3u8 I think it was my server or my DNS problem, but is not, the LINK is working fine on VLC
Luke 42244 Posted January 9, 2019 Posted January 9, 2019 Hi there, can you please attach the complete emby server and ffmpeg log? thanks.
jathe 9 Posted January 9, 2019 Author Posted January 9, 2019 2019-01-09 03:44:47.173 Error MediaSourceManager: Error probing live tv stream *** Error Report *** Version: 3.6.0.84 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.43 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 6 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: ffprobe failed for "http://189.203.173.21/LIVE/H01/CANAL107/PROFILE05.m3u8"- streams and format are both null: { } ffprobe version 4.0.2-emby_2018_12_09 Copyright © 2007-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --cc=x86_64-pc-linux-gnu-gcc --arch=x86_64 --prefix=/home/embybuilder/Buildbot/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-vdpau --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --enable-libsmbclient --enable-cuda --enable-cuvid --enable-libmfx --enable-nvenc --enable-vaapi --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --extra-libs='-lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -ldl -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -luuid -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [http @ 0x1b89780] HTTP error 404 Not Found http://189.203.173.21/LIVE/H01/CANAL107/PROFILE05.m3u8:Server returned 404 Not Found at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, String cacheKey, Boolean addProbeDelay, Boolean isLiveStream, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext() at Emby.Server.MediaEncoding.Encoder.MediaEncoder.GetMediaInfoInternal(String inputPath, String primaryPath, MediaProtocol protocol, Boolean extractChapters, String probeSizeArgument, Boolean isAudio, Boolean forceEnableLogging, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.AddMediaInfoWithProbe(MediaSourceInfo mediaSource, Boolean isAudio, String cacheKey, Boolean addProbeDelay, Boolean isLiveStream, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken)
Luke 42244 Posted January 9, 2019 Posted January 9, 2019 Again this is only a portion of a log file. What I'd really like to see is the entire log file. Can you please attach that? Thanks !
Luke 42244 Posted January 9, 2019 Posted January 9, 2019 here you go, your iptv url is returning 404 not found: [http @ 0x1b89780] HTTP error 404 Not Found http://189.203.173.21/LIVE/H01/CANAL107/PROFILE05.m3u8: Server returned 404 Not Found
jathe 9 Posted January 9, 2019 Author Posted January 9, 2019 You can check early on the log, host was with http://sl.cdn.iutpcdn.com/LIVE/H01/CANAL107/PROFILE05.m3u8 then i moved to numeric ip host to http://189.203.173.21/LIVE/H01/CANAL107/PROFILE05.m3u8, both options not work, if you try to open the link on VLC or any player its working normally
Luke 42244 Posted January 9, 2019 Posted January 9, 2019 That one also returned 404 not found: [http @ 0x121b780] HTTP error 404 Not Found http://189.203.173.21/LIVE/H01/CANAL107/PROFILE05.m3u8: Server returned 404 Not Found
jathe 9 Posted February 3, 2019 Author Posted February 3, 2019 Hi Luke, now I have another M3U with support for 20 connections, Im facing another issue, the server is working well some time, then suddenly stop the streaming and user can not conect to channels, I disabled on all users the transcoding video and audio, so, all the users play the channels with direct streaming... but, about 1 hour after, the channels stop working, the weird thing here is that when it happends, I just go to my ubunutu server and do "service emby-server restart" and channels works again, so, my question here, did I need to do any extra settings on my server? Im running emby as root, I dont have the emby user added to my server and I did install ffmpeg library and the matroskas mkvmerge. any help or hint will be aprecciated... My server is core i5, 32gb ram, 4 tb hard drive and 1gps bandwhit... thanks in advance
Luke 42244 Posted February 3, 2019 Posted February 3, 2019 We'd have to look at an example using the same set of log files as before. thanks !
