Is my card capable of Open GL?
Guest asrequested
Yep that works for as well
Curious. I was expecting that to fail. Try again with
hwdec=auto
scale=spline36
Guest asrequested
That works too
hmmmm....I wonder if your Theater installation is corrupt? Try a clean install of Theater.
After install should I change any settings?
Guest asrequested
Just use it as you choose. Whatever settings you want.
Edited by Doofus
Ok so if I change nothing I get playback.
If I select nvdec copy back, openGL and spline36 it is working. If I try ewa_lanzcos sharp no playback.
Well now things seem to be working....been going through each scaling method and it each allows playback
Guest asrequested
 I think something got corrupted in your installation. I'm glad it's working ok :)
  • Like 1
Thank you for walking me through the steps! Now to finally fix my metadata on recordings lol
