EODCrafter 181 Posted February 26, 2019 Posted February 26, 2019 Would like to Piggy Back on this if I may........ Why is it better to use Software Decoding compared to this? FPS with HW enabled is @5-10 but when I switch it off it jumps to 50-60. Is it cause this GPU is just too old?
EODCrafter 181 Posted February 26, 2019 Posted February 26, 2019 (edited) Are you running Docker on OMV? No go ahead and delete that, just thought I would slip it in. Edited February 26, 2019 by EODCrafter
sephx 5 Posted February 26, 2019 Posted February 26, 2019 (edited) in docker container devices, just add /dev/dri not a specific number. permissions should look like this on /dev/dri. they reset on boot. drwxrwxrwx 2 root root 80 Feb 26 21:52 by-pathcrwxrwxrwx 1 root video 226, 0 Feb 26 21:52 card0crwxrwxrwx 1 root video 226, 128 Feb 26 21:52 renderD128 check the user running emby is part of the video group. add user to video group with usermod -a -G video USERNAME Edited February 26, 2019 by sephx
ZiemaF 0 Posted February 27, 2019 Author Posted February 27, 2019 It looks like everything is ok But then I do not see the graphics card in EMBY root@OMV:/dev/dri# id docker uid=1001(docker) gid=100(users) grupy=100(users),44(video),996(docker) root@OMV:/dev/dri# ls -l razem 0 crwxrwxrwx 1 root video 226, 0 lut 25 07:17 card0 crwxrwxrwx 1 root video 226, 128 lut 25 07:17 renderD128
ZiemaF 0 Posted March 19, 2019 Author Posted March 19, 2019 Unfortunately, I gave up. I can not run it on OpenMediaVault 4.0. I am now waiting for OMV5.0, it will be on Debian 10, then maybe it will work. On windows 10 and windows server 2019 it works perfectly (I installed myself for testing for a moment) Overall, I'm very happy with the EMBY server on OMV through Docker I also recommend OMV to everyone, a great solution for the home server.
Luke 42246 Posted June 18, 2019 Posted June 18, 2019 https://www.youtube.com/watch?v=Rbee3Se24Ms What is this?
Riggs 312 Posted June 18, 2019 Posted June 18, 2019 What is this? Installing Emby, a Plex alternative, in Openmediavault
scheideggstrasse 0 Posted July 6, 2020 Posted July 6, 2020 On 3/19/2019 at 8:40 AM, ZiemaF said: Unfortunately, I gave up. I can not run it on OpenMediaVault 4.0. I am now waiting for OMV5.0, it will be on Debian 10, then maybe it will work. On windows 10 and windows server 2019 it works perfectly (I installed myself for testing for a moment) Overall, I'm very happy with the EMBY server on OMV through Docker I also recommend OMV to everyone, a great solution for the home server. have you tried running it at root (not good, but worth a test) docker run -d --privileged --volume /var/lib/emby-docker/:/config --device /dev/dri/:/dev/dri/ --publish 8096:8096 --publish 8920:8920 --env UID=0 --env GID=0 --env GIDLIST=0 emby/embyserver:latest
bgeneto 0 Posted March 28, 2021 Posted March 28, 2021 On 2/25/2019 at 8:55 AM, sephx said: Not sure if you got this problem fixed. Others mentioned adding devices, nobody mentioned /dev/dri permissions? If use portainer to manage docker. Edit Emby, find Runtime & Resources Tab. Add Device - > /dev/dri Rebuild your container. Permissions so container can talk to igpu = chmod -R 777 /dev/dri (rebuilt on server boot, best to add in to compose/boot scripts) Hope that helps! Spent several hours trying to figure out why adding GIDs from "video" (44) and "render" (107) groups to GIDLIST in docker-composer.yml does not work. I think there is a problem with permissions specific to the "renderD128" device owned by root:render in Debian Buster host. I've double checked the GIDLIST and it has the correct GIDs from "video" and "render" groups. But still getting error Message: "Failed to open the drm device /dev/dri/renderD128". I gave up since the permission trick did the job. Unfortunately this is only a temporary workaround. For a permanent workaround I suggest creating a new udev rule, say: /etc/udev/rules.d/99-dri.rules with the following contents: KERNEL=="card[0-9]*", GROUP="video", MODE="0666" KERNEL=="renderD*", GROUP="video", MODE="0666" Reboot the host machine and voila! vaapi with Intel Graphics HD working properly via emby docker container.
Luke 42246 Posted March 29, 2021 Posted March 29, 2021 @bgeneto that's great info, thanks for sharing.
