jangle 1 Posted January 6, 2019 Posted January 6, 2019 I have checked and the latest version under the package center is 3.5 when will 3.6 be available? Regards, Stuart
Luke 42241 Posted January 6, 2019 Posted January 6, 2019 3.6 is only in beta. It will go stable soon. Thanks.
jangle 1 Posted January 6, 2019 Author Posted January 6, 2019 I assume that even though I have BETA set on Emby this isn't available?
FrostByte 5453 Posted January 7, 2019 Posted January 7, 2019 pm solabc16 and he can add you to the beta
ace1025 0 Posted January 7, 2019 Posted January 7, 2019 Is there another source for the latest beta? I have tried sending a pm to solabc16 to no avail.
Luke 42241 Posted January 7, 2019 Posted January 7, 2019 Is there another source for the latest beta? I have tried sending a pm to solabc16 to no avail. He has been traveling. I would just him a little time. Thanks.
solabc16 379 Posted January 12, 2019 Posted January 12, 2019 Hello @@ace1025 I did get back to you in < 24hrs, but I'm all for enthusiastic and eager users Best - James
