Eltonmaster 0 Posted January 6, 2019 Posted January 6, 2019 Hey guys,I stumbled upon your awesome piece of software about a month ago.Since then I am working my way up to a complete automated build.Right now I would like to understand how the POST request works.I am trying my hardest since two days to be able to update the whitelisted IP-Addresses using nodejs. When I copy the complete json using Postman everything works just fine.But when I try to get the json from the server and just reupload it (for testing purposes) it resets my settings on the server (success code 204).It may be a simple http error that I am unable to see. Here is my nodejs playground so far. const request = require('request'); var obj request('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f', (err, res, body) => { if (err) { return console.log(err); } var inbetween = JSON.parse(body); obj = inbetween; }); JSON.stringify(obj); var options = { uri: 'http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f', method: 'POST', json : obj }; console.log(obj); request(options, function (error, response, body) { if (!error && response.statusCode == 204) { console.log(body.id) // Print the shortened url. } console.log(response.statusCode); // console.log(body); }); If you need some server logs just say so.Eltonmaster
Luke 42234 Posted January 6, 2019 Posted January 6, 2019 Hi, I would check the request body and make sure it contains the configuration object. Please let us know if this helps. Thanks.
Eltonmaster 0 Posted January 6, 2019 Author Posted January 6, 2019 (edited) When I log the request body (without tempering with it) it contains the settings json as one long string.Interesting as it is if I copy that logged out one long string into postman it resets the emby setting too.But when I pretty print it the right way, the server accepts it. I tried it again and when I post a copy of the whole body into postman it works.The problem has to be related to how I post the data in nodejs Edited January 6, 2019 by Eltonmaster
Eltonmaster 0 Posted January 6, 2019 Author Posted January 6, 2019 I changed my code a bit and now I get 500 as status code.As I wrote before, I saved the body and posted it using postman and it works just fine.logging out the options object looks as expected (although the obj is wrapped by ' (which is probably normal but I am grabbing straws here)). const request = require('request'); const fs = require('fs'); var obj request('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f', (err, res, body) => { if (err) { return console.log(err); } // console.log(body); fs.writeFile('body.txt', body, (err) => { if (err) throw err; console.log('file saved'); }); obj = body; var options = { uri: 'http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f', method: 'POST', json : obj }; console.log(options.json); request(options, function (error, response, body) { if (!error && response.statusCode == 204) { // console.log(body.id) // Print the shortened url. } console.log(response.statusCode); // console.log(body); }); });
Luke 42234 Posted January 6, 2019 Posted January 6, 2019 I would suggest comparing to what our js api library is doing: https://github.com/MediaBrowser/Emby.ApiClient.Javascript/blob/master/apiclient.js#L2682 Thanks.
Eltonmaster 0 Posted January 6, 2019 Author Posted January 6, 2019 It works now, but sadly not because I understood why, but because I swapped my http library and now it just works flawless.Thank you for the help tho.My now working Code: const unirest = require('unirest'); const readline = require('readline-sync'); unirest.get('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f',(response) => { var importconfig = response.raw_body; var fileedit = JSON.parse(importconfig); fileedit.RemoteIPFilter.push(readline.question('IP to add: ')); console.log(fileedit); unirest.post('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f') .headers({'Content-Type': 'application/json'}) .send(JSON.stringify(fileedit)) .end(function (response) { console.log(response); }); });
cielpy572 2 Posted March 8, 2023 Posted March 8, 2023 current_cfg=$(curl -v http://192.168.33.120:8096/emby/System/Configuration\?api_key\=8bfdd5) echo $current_cfg curl -v -X POST http://192.168.33.120:8096/emby/System/Configuration\?api_key\=8bfd\ --data "$current_cfg" Same problem with curl curl 7.79.1 (x86_64-apple-darwin21.0) libcurl/7.79.1 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.11 nghttp2/1.45.1 Release-Date: 2021-09-22 Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtsp smb smbs smtp smtps telnet tftp Features: alt-svc AsynchDNS GSS-API HSTS HTTP2 HTTPS-proxy IPv6 Kerberos Largefile libz MultiSSL NTLM NTLM_WB SPNEGO SSL UnixSockets Emby server version 4.7.8.0
cielpy572 2 Posted March 10, 2023 Posted March 10, 2023 On 3/8/2023 at 6:13 PM, cielpy572 said: current_cfg=$(curl -v http://192.168.33.120:8096/emby/System/Configuration\?api_key\=8bfdd5) echo $current_cfg curl -v -X POST http://192.168.33.120:8096/emby/System/Configuration\?api_key\=8bfd\ --data "$current_cfg" Same problem with curl curl 7.79.1 (x86_64-apple-darwin21.0) libcurl/7.79.1 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.11 nghttp2/1.45.1 Release-Date: 2021-09-22 Protocols: dict file ftp ftps gopher gophers http https imap imaps ldap ldaps mqtt pop3 pop3s rtsp smb smbs smtp smtps telnet tftp Features: alt-svc AsynchDNS GSS-API HSTS HTTP2 HTTPS-proxy IPv6 Kerberos Largefile libz MultiSSL NTLM NTLM_WB SPNEGO SSL UnixSockets Emby server version 4.7.8.0 Post needs some header set curl -X POST "http://192.168.33.120:8096/emby/System/Configuration?api_key=" -H "accept: */*" -H "Content-Type: application/json" -d "$new_cfg" This will be ok. 1
Cheesegeezer 3106 Posted March 21, 2023 Posted March 21, 2023 On 06/01/2019 at 17:25, Eltonmaster said: It works now, but sadly not because I understood why, but because I swapped my http library and now it just works flawless. Thank you for the help tho. My now working Code: const unirest = require('unirest'); const readline = require('readline-sync'); unirest.get('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f',(response) => { var importconfig = response.raw_body; var fileedit = JSON.parse(importconfig); fileedit.RemoteIPFilter.push(readline.question('IP to add: ')); console.log(fileedit); unirest.post('http://localhost:8096/emby/System/Configuration?api_key=5058514e6c2443a9b03cbcbcf308f06f') .headers({'Content-Type': 'application/json'}) .send(JSON.stringify(fileedit)) .end(function (response) { console.log(response); }); }); Check out my adminbuddy repo on GitHub. It collects all the server settings and is most JS. https://github.com/Cheesegeezer/Emby.AdminBuddy/blob/master/Configuration/AdminCopyUserConfigurationPage.js
