cmacfarlane93 10 Posted January 6, 2019 Posted January 6, 2019 I have a working XML guide file for my m3u playlist and emby isn't populating programming.
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 Hi there, please attach the information requested in how to report a problem. thanks !
cmacfarlane93 10 Posted January 6, 2019 Author Posted January 6, 2019 I don't see how this helps there are no error logs from this, just no EPG is being shown.
kanipek 230 Posted January 6, 2019 Posted January 6, 2019 Logs will be able to isolate the problem. If there is one. Have you tried to map the channels? That would be my guess as to what needs to be done. Logs will tell. Sent from my SM-N900T using Tapatalk
kanipek 230 Posted January 6, 2019 Posted January 6, 2019 Also to directly answer your question. XMLTV files are supported. I use them daily - not for IPTV but CATV. Sent from my SM-N900T using Tapatalk
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 I don't see how this helps there are no error logs from this, just no EPG is being shown. Have you checked the dates in your xmltv file to make sure it has programs for the dates you're looking at? Have you checked the mapping tool to make sure that your tuner channels are mapped to xmltv channels?
cmacfarlane93 10 Posted January 6, 2019 Author Posted January 6, 2019 (edited) I have the log file but Im concerned about pasting it here with sensitive information, but I am having the same issue. Edit when i select map channels nothing is appearing in a list Edited January 6, 2019 by cmacfarlane93
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 We'd need to see the server log. You can always PM to me. Thanks.
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 It looks like vaders xmltv api is returning invalid xml, and that's why emby has trouble parsing it.
cmacfarlane93 10 Posted January 6, 2019 Author Posted January 6, 2019 But I also have schedules direct applied shouldnt that be working?
Luke 42244 Posted January 6, 2019 Posted January 6, 2019 What problem are you having with schedules direct?
