cg0 0 Posted January 6, 2019 Posted January 6, 2019 Trying to use Emby TV (the HTML5 app) on my TV, however whenever I get to the screen asking me to enter my pin on ember.media/pin the site accepts it however the web app seems to stay there doing nothing. Since some tit at Philips left remote debugging enabled I can see the web app is getting constant 404s trying to request https://connect.emby.media/service/pin It is also worth noting that the UI on the TV is slightly different that what loads on my Mac when I try to go to the same URL. I have attached a screenshot of where I am stuck (sorry for the resolution, literally taken from the Chrome debug screen) TV: Phillips 55PUS6503 Cheers
Luke 42242 Posted January 6, 2019 Posted January 6, 2019 Hi, those are not the right login urls, can you please use the url displayed on screen instead? https://emby.media/pin Thanks !
cg0 0 Posted January 6, 2019 Author Posted January 6, 2019 Maybe I explained this a bit wrong but I did use emby.media/pin to enter my pin however the TV did nothing, looking at the javascript console on the TV I see a lot of 404 errors with the web app attempting to contact https://connect.emby.media/service/pin (with get parameters that seem to identify my TV and the PIN which I truncated) Does that explain it better?
Luke 42242 Posted January 6, 2019 Posted January 6, 2019 That's strange, i just tested and it worked fine. can you supply the complete console output? thanks.
cg0 0 Posted January 6, 2019 Author Posted January 6, 2019 The useragent is identifying as Chrome/49 ouch.
Luke 42242 Posted January 6, 2019 Posted January 6, 2019 I've pushed an update. Can you please try again, only this time, please click Skip on that screen and then connect to your server manually. Thanks.
