DrJekle 4 Posted January 6, 2019 Posted January 6, 2019 I was watching a movie and got to the ~50 minute mark when Emby stopped playback. When I resumed, it played for a few seconds and stopped again. Restarting server and computer did not help. embyserver.txt embyserver-63682319951.txt ffmpeg-remux-1fe7d366-a078-4b90-a3a4-19658c9da2bc.txt
Luke 42216 Posted January 6, 2019 Posted January 6, 2019 Hi, this happened one time, or is this a regular thing?
DrJekle 4 Posted January 6, 2019 Author Posted January 6, 2019 First time I've had this happen where a restart didn't fix the issue
DrJekle 4 Posted January 6, 2019 Author Posted January 6, 2019 I should add I typically use theater, but lately I have not been able to get any playback started using theater
Luke 42216 Posted January 6, 2019 Posted January 6, 2019 What happens when you try to play with Theater?
DrJekle 4 Posted January 6, 2019 Author Posted January 6, 2019 Just spins, doesn't matter if it's live TV or a movie. Figured I would just use the server until I had time to figure out more with the theater side but now that is having isses figured best to start at A than work to B
Luke 42216 Posted January 6, 2019 Posted January 6, 2019 Is Windows fully up to date, along with all graphics drivers?
Happy2Play 9806 Posted January 6, 2019 Posted January 6, 2019 By chance could your C: drive be full? Is there any old content in your "\Emby-Server\programdata\transcoding-temp"?
DrJekle 4 Posted January 6, 2019 Author Posted January 6, 2019 Graphic drivers all updated windows 10 updates itself. I have to check the c drive
