rapteev 20 Posted January 6, 2019 Posted January 6, 2019 Hi Emby for Kodi stop updating libraries after installing latest Kodi nightly , that also update database to 114. Even a manual update do not work. Thank you
Luke 42239 Posted January 6, 2019 Posted January 6, 2019 Hi, what does "not work" mean? What happens when you try a manual update?
rapteev 20 Posted January 6, 2019 Author Posted January 6, 2019 Hi Doing a manual update also do not update library. I have 2 nvidia shield and only installed the latest nightly in one of them. The other one is running rc3 and everything is running/updating as expected. Thank you
Angelblue05 4132 Posted January 6, 2019 Posted January 6, 2019 (edited) It's because they updated the version of the database. I am not around until tomorrow, what you can do for now if you can edit the file in notepad: userdata/addon_data/plugin.video.emby/emby/objects/obj_map.json, edit the videodb to 114. Edited January 6, 2019 by Angelblue05
rapteev 20 Posted January 6, 2019 Author Posted January 6, 2019 Ok. Thank you , I will try that, but i remember to read a post where you state that this kind of changes to Kodi database shouldn’t impact on the plugin... anyway thank you for your great work.
sualfred 677 Posted January 6, 2019 Posted January 6, 2019 (edited) A version bump always requires code adjustments. Just change it like Angelbue said or go back to a older nightly in the meantime. This also solves the problem. Edited January 6, 2019 by sualfred
Angelblue05 4132 Posted January 6, 2019 Posted January 6, 2019 Yes still working on the process. Thanks for the feedback.
mary022 0 Posted January 9, 2019 Posted January 9, 2019 (edited) The only way that I can make a new show be entered into my Kodi library is to go to Vidoes---->Files---->TV Shows---->Press "C"---->Scan to library. That only works on a single show. When I choose "Update Library" anywhere within Kodi, it goes through the motions, but doesn't come up with anything new and there are at least 40 shows that have not been scraped yet. Edited January 14, 2019 by mary022
Angelblue05 4132 Posted January 9, 2019 Posted January 9, 2019 You’ll have to either repair but likely do a reset as it sounds you’ve messed around with scanning content directly into Kodi. I am working on a fix to allow it to pick up on the new db version which is why you are not seeing updates, as it’s writing to the old database atm. Thanks for your patience.
