notla49285 48 Posted January 5, 2019 Posted January 5, 2019 As per the title really, my TV guide on Roku is a complete mess. It seems to be that it's listing channels in the most recently viewed order (descending), therefore keeps changing. I don't know if this is intentional or a bug but it is NOT usable. Can anyone help?
Luke 42242 Posted January 6, 2019 Posted January 6, 2019 Hi, does this happen in the web app? Can you please go over an example? thanks.
notla49285 48 Posted January 6, 2019 Author Posted January 6, 2019 Hi, does this happen in the web app? Can you please go over an example? thanks. No, this doesn't happen on the web app. Below is an example of the Roku app, channels are listed in most recent order:
Solution Crooze 2 Posted January 6, 2019 Solution Posted January 6, 2019 Log into the web app as the same user that is used on the roku. Go to the guide and click the ... and select the sort. 1
notla49285 48 Posted January 6, 2019 Author Posted January 6, 2019 (edited) Log into the web app as the same user that is used on the roku. Go to the guide and click the ... and select the sort. This was already set to channel number, so I changed it to recently watched, waited for the list to update on the web app then changed it back to channel number. This has fixed the ordering on the Roku. Thanks @@Crooze! Edited January 6, 2019 by notla49285
Luke 42242 Posted January 6, 2019 Posted January 6, 2019 Thanks for the feedback. All of this needs review and redesign in the future. 1
