Operator Error? Remote Control and Mute Button
When I have my Nexus 7, connected to WiFi, and select a movie, then tell it to play on my MB3 on Windows Media Center Windows 7 HTPC, the remote controls pop up. Awesome, but once you navigate away from the controls they are gone, and the only way to get them back is to restart the movie. also the mute button crashes app instantly. Which aggrivates the previous issue.
Redshirt
I haven't been able to recreate the mute button crash. Which app version are you using? The google play or amazon store version. Are we talking about a physical button on the device, or the software button on the remote control UI?
Edited by Redshirt
