xe` 45 Posted January 3, 2019 Posted January 3, 2019 The original thread https://emby.media/community/index.php?/topic/57771-emby-kodi-profiles-and-thumbnail-spaceduplication-issues/ is locked and I cant use it to post updates or fixes. (locking old threads on a forum that users contribute guides and support to is a silly policy btw) So to close this off. Kodi has hobbled path substitution in the next version and as such this technique likely wont ever work again. Not going to continue wasting effort documenting here but if anyone wants to work on it with me (or see the eventual solution) catch me on LibreELEC IRC.
Angelblue05 4132 Posted January 3, 2019 Posted January 3, 2019 Things are this way to make it easier to maintain this section of the forum. If you need me to reopen the old thread from 2016 I will. What exactly do you mean by hobbled path substitution?
xe` 45 Posted January 3, 2019 Author Posted January 3, 2019 There is a large back story but.. https://kodi.wiki/view/Advancedsettings.xml#pathsubstitution `Note: Path substition for "sources" and profiles is broken, and will NOT be fixed.` You can read some more in this thread which I warn in advance is not a very friendly read. https://forum.kodi.tv/showthread.php?tid=336371 tl;dr path is way less capable now, to the point it can no longer work with my documented solution Of other note from this thread https://forum.kodi.tv/showthread.php?tid=336371&pid=2781830#pid2781830 `Next up will be profiles being ripped out and redone completely` If you want to merge this thread with the old one please feel free to do so. I would also suggest that a wiki would be a better fit for documents such as these.
