Hdnauta 0 Posted January 2, 2019 Posted January 2, 2019 Hello All, I installed Emby server on my Mac (2014) and my library is on a network volume conneted via usb port on the router (usb2.0). When I now wnat to play music via my Heos Link (wired connection) I experience some issues when playing hd audio flac (large) files. Normal flac files are running fine. I'm thinking of a performance issue, anyone an idea on how to improve this? Thanks.
Luke 42239 Posted January 2, 2019 Posted January 2, 2019 Hi there, can you please describe the issues? Thanks.
Hdnauta 0 Posted January 3, 2019 Author Posted January 3, 2019 The music stops and then after a few seconds it continues. Happens on alsmost every song.
Luke 42239 Posted January 4, 2019 Posted January 4, 2019 Can you please attach the emby server log, and ffmpeg log if there was one? thanks !
