indyjones 3 Posted January 1, 2019 Posted January 1, 2019 (edited) Hi all, Happy new year to you all. I am looking for a new NAS device for my parents, and while emby supports a number of different devices (it's currently running on their Asustor), I thought I would post here to enquire what was the best NAS brand purely to run emby. It is not being used for recording any live TV only sending video to a couple of Roku devices, and streaming audio via DLNA to a number of devices. It does not really need to be able to transcode multiple streams, however I do want it to be responsive (the Asustor locks up on chapter image extraction for example). Thank you. Edited January 1, 2019 by indyjones
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 I have a WD PR2100 and It works very well with the last beta, even with a pair of devices transcoding 1080p. It does not have enough power to transcode 4K. https://www.wd.com/products/network-attached-storage/my-cloud-pr2100.html If you don't need transcoding, you could find cheaper solutions.
indyjones 3 Posted January 1, 2019 Author Posted January 1, 2019 Thanks, I will look into the WD ones. I guess an Intel chipset is preferred?
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 Thanks, I will look into the WD ones. I guess an Intel chipset is preferred? I prefer Intel. I have tested different ARM models and the power is insufficient. Maybe, this could go well: https://emby.media/community/index.php?/blog/1/entry-446-emby-server-now-available-for-qnap-arm64-models/ I have heard very well about its processor, but I have not tested it.
indyjones 3 Posted January 1, 2019 Author Posted January 1, 2019 The WD PR2100 does look like a good option thank you, and it's a lot faster than the old Asustor cpu wise. Does emby support hardware transcoding on this device please?
vdatanet 1619 Posted January 1, 2019 Posted January 1, 2019 The WD PR2100 does look like a good option thank you, and it's a lot faster than the old Asustor cpu wise. Does emby support hardware transcoding on this device please? Yes, beta version has better support for hardware transcoding.
