Luke 42239 Posted April 9, 2019 Posted April 9, 2019 Luke, sample linked here: https://drive.google.com/open?id=1ocpY0qbs-nwf0PjQwPJuf0FGJTof9Omc Confirmed this is happening in the web app and android app; after Chromecast connects, the seek buttons disappear. Thanks a million for diving into this. This is just about the buttons? Have you tried using the seek bar?
Projectionist 0 Posted April 9, 2019 Posted April 9, 2019 Seek bar works, buttons are necessary if you want to seek accurately. Seek bar is difficult to use, especially in small form factor on phone.
elmacko 0 Posted April 9, 2019 Author Posted April 9, 2019 Just be clear, my issue is still same as original description, not being able to fast forward or resume at all when chromecasting from ios app. I also sent you sample videos, were you still not able to reproduce my problem Luke?
Luke 42239 Posted April 9, 2019 Posted April 9, 2019 Just be clear, my issue is still same as original description, not being able to fast forward or resume at all when chromecasting from ios app. I also sent you sample videos, were you still not able to reproduce my problem Luke? At the time I was able to reproduce, and then I resolved it for your specific sample files, at least in my own testing.
Luke 42239 Posted April 9, 2019 Posted April 9, 2019 Seek bar works, buttons are necessary if you want to seek accurately. Seek bar is difficult to use, especially in small form factor on phone. Ok so this is unrelated to this discussion then. Try flipping to landscape orientation. When the horizontal resolution is higher, more buttons will be available.
Projectionist 0 Posted April 9, 2019 Posted April 9, 2019 Ok so this is unrelated to this discussion then. Try flipping to landscape orientation. When the horizontal resolution is higher, more buttons will be available. Thank you for the landscape suggestion, I can work with that, though it would be nice to have the seek buttons in portrait. If I ever get really bugged about this in the future I'll create a separate thread or feature request. FYI, I did notice the seek buttons disappear in the browser on a desktop after the chromecast is connected. This is not my primary format to use so it's a non-issue. Thanks again for your work Luke.
Luke 42239 Posted April 10, 2019 Posted April 10, 2019 Soooo how did you solve it? I believe I changed the transcoding format. If you have another sample i can try i'll be happy to test that as well. thanks.
elmacko 0 Posted April 13, 2019 Author Posted April 13, 2019 I believe I changed the transcoding format. If you have another sample i can try i'll be happy to test that as well. thanks. to what and where?
elmacko 0 Posted April 14, 2019 Author Posted April 14, 2019 I meant, what transcoding settings did you change, and where. In the server settings? are there some settings in the ios app? thanks.
Luke 42239 Posted April 15, 2019 Posted April 15, 2019 No settings. I made some code changes to our Chromecast receiver.
elmacko 0 Posted April 15, 2019 Author Posted April 15, 2019 Ahaaa okay, so is this something that will be fixed in upcoming releases?
Luke 42239 Posted April 15, 2019 Posted April 15, 2019 I already fixed it for the sample file you provided a few months ago. If you have another sample file i can try, I'm happy to look at that. Thanks.
elmacko 0 Posted April 15, 2019 Author Posted April 15, 2019 Sorry that I’m so confused, but you’re saying you were able to reproduce my issues I described for the sample files I gave you, and you’ve fixed them and made a new release with the fix already? I’m still having issues with most of my files, so what you’re saying is basically that the issue is somewhat individual to each file?
Luke 42239 Posted April 15, 2019 Posted April 15, 2019 At the time I was able to reproduce it, yes, and I resolved it.
MartMH 1 Posted September 13, 2025 Posted September 13, 2025 Hi all, @Luke I think I do have the same issue as OP. From my iPhone I am casting to emby on my v2 chromecast and that goes pretty well. If I hit the +10s button that also works and no biggies there. However, if I were to skip manually by moving the progress bar to like halfway of a 2 hour movie from the start. It either takes an era to get there or it starts from the beginning. More often it starts from the beginning. I am using bunny cdn but I have disabled all caching. I am running emby in a docker container on my dell optiplex. services: emby: image: emby/embyserver container_name: embyserver restart: unless-stopped environment: - UID=1000 # The UID to run emby as (default: 2) - GID=100 # The GID to run emby as (default 2) - GIDLIST=100 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - ./config:/config - /mediapath:/mnt/media ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes networks: - traefik labels: - "traefik.enable=true" - "traefik.http.routers.emby.rule=Host(`emby.mydomain.com`)" - "traefik.http.routers.emby.entrypoints=websecure" - "traefik.http.routers.emby.tls.certresolver=bunny" - "traefik.http.services.emby.loadbalancer.server.port=8096" - "traefik.docker.network=network_traefik_external" networks: traefik: name: network_traefik_external external: true Any clue to what the culprit might be here? I have posted my logs to you in PM.
MartMH 1 Posted September 13, 2025 Posted September 13, 2025 (edited) I did some additional finding. When I connect to my server in the Emby app over a local connection, directly using the server IP 192.168.50.10, the issue is not present. so most likely some issue with my cdn bunny or reverse proxy traefik. Do you maybe have suggestions? what’s more, I have a remote control that can pause the tv/chromecast.. this didn’t work on by using the domain name based connection but does work when using the direct connection. Edited September 13, 2025 by MartMH
MartMH 1 Posted September 13, 2025 Posted September 13, 2025 Just keeping responding to my own messages here but think it is wise to keep this logged somewhere. Bunny CDN has just released websockets into their CDN's. I couldn't find the physical button (yet) but enabling websockets can be done using the API which they provide a quick execute function for in their documents. Steps: https://docs.bunny.net/reference/pullzonepublic_updatepullzone fill out the id which you can find in the url of your pull zone when opening it in your bunny dashboard Scroll all the way down and fill out the required `PreloadingScreenShowOnFirstVisit` to your liking Just a bit below that, change "EnableWebsockets" from false to true at the right top fill out the api key which you can find in your bunny account hit "try it" Goodluck
Luke 42239 Posted September 16, 2025 Posted September 16, 2025 On 9/13/2025 at 4:14 PM, MartMH said: I did some additional finding. When I connect to my server in the Emby app over a local connection, directly using the server IP 192.168.50.10, the issue is not present. so most likely some issue with my cdn bunny or reverse proxy traefik. Do you maybe have suggestions? what’s more, I have a remote control that can pause the tv/chromecast.. this didn’t work on by using the domain name based connection but does work when using the direct connection. Hi, have you compared your reverse proxy settings to this? The guide is based on nginx, but most reverse proxy software have similar options. thanks.
