JXL2112 7 Posted January 1, 2019 Posted January 1, 2019 So I used Foobar to batch add front covers for most of my albums. The folders had folder.jpg in them so foobar grabbed those and tagged the artwork to all the tracks. It all looked great in Windows..... Then later when I fired up Roku and started playing the albums none of the new artwork would display. I tried re-tagging a few albums but still won't display the new artwork. I also tried beta app for Roku and it did not work either. BTW: The queue order is still broken.
Happy2Play 9811 Posted January 1, 2019 Posted January 1, 2019 Did you refresh these items in Emby after making the changes?
JXL2112 7 Posted January 1, 2019 Author Posted January 1, 2019 Did you refresh these items in Emby after making the changes? Yes. Several Times. Going to do some trouble shooting....update foobar etc.
JXL2112 7 Posted January 1, 2019 Author Posted January 1, 2019 (edited) Update: OK so I found the problem:200 x 200 = no600 x 600 = no1080 x 1080 = YesApparently the Roku app will only display the large images and ignores the smaller ones. Why does the image size matter?The 200 x 200 were only 9k, the 600 x 600 were only 29k and the 1080 x 1080 were 927k. I like using smaller images since it keeps the file size down and saves space. Edited January 1, 2019 by JXL2112
JXL2112 7 Posted January 1, 2019 Author Posted January 1, 2019 OK so after troubleshooting I found that the 200 x 200 do work but I need to also hit refresh in the Roku app manually. That is going to be a pain for every album. Does the Roku app grab artwork from a cache on the Emby Server? Anyway to rebuild this cache?I know the Roku isn't storing anything...so it has to be on the Server.
