BillOatman 597 Posted January 1, 2019 Posted January 1, 2019 (edited) Like I said, just an annoyance but, if I look at the guide at 17:45 and select a show, then go back to the guide at 18:05, the start time of the guide still shows 17:30 instead of 18:00. If I exit out of the guide and go back in, it starts at 18:00 as it should. Please adjust the start time of the grid on every entrance to the guide, not just when entering from the main menu. I'm using a shield if that makes a difference. Edited January 1, 2019 by BillOatman 1
ebr 16337 Posted January 1, 2019 Posted January 1, 2019 Hi. The guide will refresh itself once it is 45 minutes past the currently displayed start time. Why do you feel it has to be more aggressive than this?
BillOatman 597 Posted January 1, 2019 Author Posted January 1, 2019 (edited) Hi. The guide will refresh itself once it is 45 minutes past the currently displayed start time. Why do you feel it has to be more aggressive than this? i'd need to test again to be 100% sure, but when you are in this mode and a new show has begun (for example the guide begins at 17:30, it is 18:05 and a different show started at 18:00), and you select the show that starts at 18:00, you get the popup for scheduling a future recording. You need to select the show that has ended to tune to that channel. I would think moving ahead to the current time always makes the most sense. What's the reason for waiting 45 minutes? Edited January 1, 2019 by BillOatman
ebr 16337 Posted January 1, 2019 Posted January 1, 2019 i'd need to test again to be 100% sure, but when you are in this mode and a new show has begun (for example the guide begins at 17:30, it is 18:05 and a different show started at 18:00), and you select the show that starts at 18:00, you get the popup for scheduling a future recording. You need to select the show that has ended to tune to that channel. I don't believe that is true. You can tune to the channel from either place. (or you can just hit the play button on your remote) I would think moving ahead to the current time always makes the most sense. What's the reason for waiting 45 minutes? Performance. Also, it isn't always a bad idea to see what was just on immediately after it has ended as opposed to that disappearing the second it is over with.
BillOatman 597 Posted January 2, 2019 Author Posted January 2, 2019 I don't believe that is true. You can tune to the channel from either place. (or you can just hit the play button on your remote) Performance. Also, it isn't always a bad idea to see what was just on immediately after it has ended as opposed to that disappearing the second it is over with. I primarily use a shield, and it's remote is button challenged I'll try and test what happens on the selection tonight. Yeah I can see why you might want the previous show up for a few minutes I guess. Personally I'd prefer to see the guide advance and have the ability to scroll to the left to see past shows.
ebr 16337 Posted January 2, 2019 Posted January 2, 2019 I primarily use a shield, and it's remote is button challenged Double-tapping the volume slider is "play" on that remote (intuitive, huh... ) 1
BillOatman 597 Posted January 8, 2019 Author Posted January 8, 2019 I guess I forgot to comment back, sorry for the delay. I tried it, and I can tune the channel when I move ahead in the guide. Not sure why I thought I couldn't before. Must have been trying multiple things, or had a few too many adult beverages. But thanks!
Guest asrequested Posted January 8, 2019 Posted January 8, 2019 I actually think it should move at the very least in 30min intervals. Ultimately, I'd want it in real time. And that's in every app. The theater guide is often out of step, where the highlighted shows are no longer current. The guide should be active and align itself with the current time.
Luke 42245 Posted January 8, 2019 Posted January 8, 2019 The automatic refreshing in Theater should be a bit better nowadays.
Guest asrequested Posted January 8, 2019 Posted January 8, 2019 The automatic refreshing in Theater should be a bit better nowadays. Here's my circumstance. I often leave it on guide overnight. Almost every morning, it's out of alignment. It's not a huge deal, but the point of the shading is to show you what's currently playing. But it's often out of step.
ebr 16337 Posted January 8, 2019 Posted January 8, 2019 Here's my circumstance. I often leave it on guide overnight. Almost every morning, it's out of alignment. It's not a huge deal, but the point of the shading is to show you what's currently playing. But it's often out of step. That should never be the case in this app.
Guest asrequested Posted January 9, 2019 Posted January 9, 2019 You've seen that recently? Almost every day.
Luke 42245 Posted January 10, 2019 Posted January 10, 2019 The guide screen, or the home screen showing programs?
Guest asrequested Posted January 10, 2019 Posted January 10, 2019 The guide screen, or the home screen showing programs? The guide.
