ken-ji 0 Posted January 20, 2019 Author Posted January 20, 2019 [HorribleSubs] Black Clover - 64 [720p].mkv
ken-ji 0 Posted January 20, 2019 Author Posted January 20, 2019 That's correct. it is a symlink; actual file is in the parent directory. I've set it up to limit Emby from seeing all the unneccessary directories and archives.
Luke 42244 Posted January 21, 2019 Posted January 21, 2019 Ok I apologize but unfortunately that's not going to work at this time because we are blocked due to limitations in the .NET Core runtime: https://github.com/dotnet/corefx/issues/26310 The reason it works with transcoding is because ffmpeg ends up processing the file.
ken-ji 0 Posted January 21, 2019 Author Posted January 21, 2019 Ok. thanks for the heads up. I can fix this on my end - but before that, I suppose a hard link would work as there is no difference between hard links and the origin file?
ken-ji 0 Posted January 22, 2019 Author Posted January 22, 2019 Ok. problem solved. I've reshuffled stuff and replaced them with hard links Thanks!
