mwkurt 5 Posted December 29, 2018 Posted December 29, 2018 (edited) Hello, I have purchased Emby Premiere just so I could record some shows using an IPTV account I have. Have found that any recording that I make will freeze every few seconds for 5 or 10 seconds then repeat the cycle. The IPTV account I have allows 5 simultaneous connections, so that shouldn't be a problem. Reading a bit using Google, I have learned that maybe to record IPTV you need 2 connections?? Is there anything I can do inside of Emby to get rid of the freezing and skipping? Forgot to add, I can watch the IPTV Streams live with no problems at all. Thanks, Mark Edited December 29, 2018 by mwkurt
Luke 42244 Posted December 29, 2018 Posted December 29, 2018 Hi there, welcome. Can we look at an example? Please attach the emby server log, as well as the recording conversion log if there was one. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
Luke 42244 Posted December 29, 2018 Posted December 29, 2018 Also are you playing the completed recording, or is it still in progress?
mwkurt 5 Posted December 29, 2018 Author Posted December 29, 2018 Also are you playing the completed recording, or is it still in progress? Trying to watch them after recording is completed. Here are the relevant files. All the log files and three recorded shows, all exhibiting the same behaviour. https://www.dropbox.com/sh/rdzns58zrgsdv0d/AAB46bVLjHvGtIDDpfkYBWXJa?dl=0
Luke 42244 Posted December 29, 2018 Posted December 29, 2018 Are you able to play the completed files in something like vlc? That might not be the best test though since vlc generally handles everything. but it's worth finding out.
mwkurt 5 Posted December 29, 2018 Author Posted December 29, 2018 Are you able to play the completed files in something like vlc? That might not be the best test though since vlc generally handles everything. but it's worth finding out. VLC is what was using to initially view the files and is how I noticed the freezing.
mwkurt 5 Posted December 30, 2018 Author Posted December 30, 2018 So you're saying they freeze in vlc? They freeze in anything I play them in. VLC or playback using Emby. They are recorded with the freezing embedded in them. Did you look at them? The logs? Anything you ask for that I provided? Do you have any answers? Thanks, Mark
Luke 42244 Posted December 31, 2018 Posted December 31, 2018 I would suggest trying this again with the upcoming 3.6 release of Emby Server. Thanks.
