jaimedelano 1 Posted January 1, 2019 Author Posted January 1, 2019 I need NFS. I have many terabytes of videos. I can play them on Plex, but I want to use Emby too.
jaimedelano 1 Posted January 1, 2019 Author Posted January 1, 2019 Is there any workaround?For example, a pre play script to copy remote files to local disk on demand?
Luke 42244 Posted January 2, 2019 Posted January 2, 2019 When error ocurrs it seems the server serve up partial contents of the video file. 2019-01-01 13:56:26.826 Debug HttpResultFactory: Transmit file /storage/iptv/filmes/pro/#HORROR.mp4 2019-01-01 13:56:27.026 Info HttpServer: SocketException: http://MY_SERVER_IP:8096/emby/Videos/7442/stream.mp4?Static=true&mediaSourceId=XXX&deviceId=YYY&api_key=ZZZ curl -L 'http://MY_SERVER_IP:8096/emby/Videos/7442/stream.mp4?Static=true&mediaSourceId=08aafed7364a23f17cb2ad1c8ef78aae&deviceId=XXX' $ftypisomisomiso2avc1iso6mp41�moovlmvhd If I replace Static=true with Static=false in the URL, I can see the whole video contents: curl -L 'http://MY_SERVER_IP:8096/emby/Videos/7442/stream.mp4?Static=false&mediaSourceId=08aafed7364a23f17cb2ad1c8ef78aae&deviceId=XXX' Exactly, because when you stream the original file statically, we use .net core I/O methods to transmit the original file, and this is where the limitation lies. When ffmpeg is involved, it supports the nfs links natively, and that's why there's no problem. Sorry, I will investigate, but I'm not sure we can do anything about this.
jaimedelano 1 Posted January 2, 2019 Author Posted January 2, 2019 Update: I think this issue is not related specifically to NFS. I guess the main point is that is Emby/.Net core does not support symbolic links.I have replaced all symbolic links with hard links and now Emby plays the videos.
Luke 42244 Posted January 2, 2019 Posted January 2, 2019 Yes that is correct. We are waiting on this: https://github.com/dotnet/corefx/issues/26310
