higaseiti 0 Posted December 28, 2018 Posted December 28, 2018 (edited) 1- Any idea to be deployed subtitle color change option?(most important) 2- Is the subtitle in Brazilian Portuguese in small option, the size still large, some idea of something smaller than the {small subtitle} option ?? Very Small maybe? 55NU7400 Brazil Tks Edited December 28, 2018 by higaseiti
Luke 42241 Posted December 28, 2018 Posted December 28, 2018 Hi, yes this is planned for the future, thanks ! 1
MrMind 2 Posted January 6, 2019 Posted January 6, 2019 Subtitle color change will be very useful for watching HDR movies. Sometimes when I watch HDR movie subtitles are so bright I can't watch on them.
pastorn 2 Posted March 28, 2019 Posted March 28, 2019 Hi there, Have you tried the following edit to your SRT files? <font color=#808080>Line</font> This worked on the LG Smart TV app up until the latest release of the app where the support disappeared. It appears that neither the support for it or the removal of the support was intentional by the developers but I hope they are able to restore this million-dollar-function to the next release. But give it a try! Maybe it still works on the Samsung release? It can sound a bit nerdy to have to edit your SRT files to get a good viewing experience but it has the upside that you can do it for HDR subs alone and leave SDR subs untouched. A setting in the app would most likely affect all subtitles. And it takes like 10s with a proper subtitle editor (select all lines, change color). Best regards Martin
Luke 42241 Posted March 28, 2019 Posted March 28, 2019 Hi there, Have you tried the following edit to your SRT files? Line This worked on the LG Smart TV app up until the latest release of the app where the support disappeared. It appears that neither the support for it or the removal of the support was intentional by the developers but I hope they are able to restore this million-dollar-function to the next release. But give it a try! Maybe it still works on the Samsung release? It can sound a bit nerdy to have to edit your SRT files to get a good viewing experience but it has the upside that you can do it for HDR subs alone and leave SDR subs untouched. A setting in the app would most likely affect all subtitles. And it takes like 10s with a proper subtitle editor (select all lines, change color). Best regards Martin Since you opened a topic about this, I'll respond here: https://emby.media/community/index.php?/topic/71879-srt-subtitle-color-support Thanks.
higaseiti 0 Posted April 4, 2019 Author Posted April 4, 2019 (edited) Hi there, Have you tried the following edit to your SRT files? <font color=#808080>Line</font> This worked on the LG Smart TV app up until the latest release of the app where the support disappeared. It appears that neither the support for it or the removal of the support was intentional by the developers but I hope they are able to restore this million-dollar-function to the next release. But give it a try! Maybe it still works on the Samsung release? It can sound a bit nerdy to have to edit your SRT files to get a good viewing experience but it has the upside that you can do it for HDR subs alone and leave SDR subs untouched. A setting in the app would most likely affect all subtitles. And it takes like 10s with a proper subtitle editor (select all lines, change color). Best regards Martin Thanks, but not work Still white... Edited April 4, 2019 by higaseiti
S3R14L 1 Posted April 21, 2019 Posted April 21, 2019 (edited) I really hope that comes option to put the yellow subtitle I have other Android TV using last beta and it's excellent, my Samsung 2016 with 1.0.59 has only white subtitles and very small size Edited April 21, 2019 by S3R14L
